> Sunroof and door panel repair question
post May 21, 2013 - 6:08 PM
BillyM81
Joined Mar 15, '11
From Belfry, kentucky
My sunroof quit working right after a friend tried to open the sunroof with the shade closed. Now it will not slide open at all, and will open up only with the slide button. I got another sunroof motor at an pull-a-part the other day, I was wanting to know how do i adjust the motor to make sure everything is lined up right when i swap out motors.
Also picked up a couple of door panels but they have cracks on the boards on the backside, i was wondering what's the best way to fix those.
Replies (1 - 6)
post May 28, 2013 - 12:50 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
i wish i could understand but i dont understand which pieces are broken. pics would help
post May 28, 2013 - 1:35 PM
BillyM81
Joined Mar 15, '11
First thanks for the reply, did not thank any one would reply,lol. On the door panels, the wooden board on the back of the door panel is what is broken. One of my door panels the arm rest has a good crack in it, and some other places has problems. I will try to take some pics
post May 28, 2013 - 2:32 PM
Its been awhile since I've looked at door panels, but you might be able to push the cracks back into place then reinforce from the inside using fiberglass?
post May 28, 2013 - 3:18 PM
BillyM81
Joined Mar 15, '11
Yeah i can push the cracks back together, i just did not know what to use to reinforce the area.
post May 29, 2013 - 11:33 PM
IfWeChoose
Joined May 25, '13
From Charlotte, NC
Absolutely use fiber glass. It'll adhere just fine to the back of the door panels and give a strong reinforcement. I went ahead and reinforced my driver's side door panel with fiberglass (right when I noticed it was weakening) and have never had an issue since using the fiberglass. I never did get around to the passenger side and the passenger side is already busted. The only crappy thing is that you'll never get the vinyl cover on the door panel to look the same again. It'll be as strong as can be though! If it's already busted, be sure to do the entire arm rest portion of the door panel.
post May 30, 2013 - 6:17 AM
BillyM81
Joined Mar 15, '11
Thanks, i will give that a try. Can you order a new sunroof motor or is the only ones you get is from the junkyards?
Lo-Fi Version Time is now: August 24th, 2026 - 7:07 PM
