> New clutch...new vibration
post Jul 18, 2013 - 7:35 PM
6G96GT
Joined Jan 20, '08
From East Coast
Got my clutch replaced today. Mechanic had to resurface the pressure plate and installed the new clutch.
When the car is in neutral it will vibrate and make a rhythmic chatter noise I guess. When the clutch pedal is pushed in, the noise stops. It doesn't do make the noise all the time so that's weird.
Any ideas?
This post has been edited by 6G96GT: Jul 18, 2013 - 7:37 PM
Replies (1 - 5)
post Jul 19, 2013 - 2:04 PM
blackliftback
Joined Mar 1, '12
From iowa
What kind of noise? Is it oem clutch?
By the sounds of it right now.... I would guess it wasnt torqued down properly. Either that or the flywheel needs to be resurfaced
post Jul 19, 2013 - 10:36 PM
yeah that doesnt sound right, you never ever re-surface the pressure plate, you replace it
post Jul 19, 2013 - 11:43 PM
mkernz22
Joined May 10, '10
From MA
Why would you not get a new pressure plate when getting a new disc? and I bet he didn't replace the throw out bearing. That's most likely your chatter.
post Jul 20, 2013 - 2:42 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
He prob took a grinder and re-surfaced it, straight edged, re-resurface and straight edged it several times. Seriously if your going to spend a ton of money on a fix get new parts.
post Jul 20, 2013 - 12:15 PM
6G96GT
Joined Jan 20, '08
From East Coast
The new clutch kit was almost $300. Wouldn't that have included everything? The mechanic I see is not a 1/2 ass kind of mechanic. He said the pressure plate was glazed over...don't know what that means. Everything shifts real nice and all.
One more thing I noticed is that when I am pulling into my driveway and change from 2nd to 1st to do that when slowing down. I can hear a sound that sounds like what I would suspect to be the clutch engaging or disengaging? I never really noticed that noise before.
Lo-Fi Version Time is now: August 11th, 2026 - 12:04 PM
