Aug 29, 2013 - 8:51 AM
Enthusiast ![]() ![]() Joined Jan 13, '12 From Georgia Currently Offline Reputation: 3 (100%) |
I have been burning up wheel bearings recently and through a process of elimination. I learned that the hub had gone out. Originally I thought the abs ring that came on the new axel I installed was grinding on the hub, so I pulled it all apart to find out it was one of the races that had come loose( don't ask me how, I put 150+ flb of torque on the axel nut) while I had it all apart I tried to tap the abs ring off (had a corolla I had to do that with once). Apparently during the process I managed to un seat the axel from the trans and it was leaking profusely. I figured I lost a quart or more fluid. So I re seated the axel and added some more fluid and yet it still leaks, not as bad as before though. Probably about 1 decent sized drop every 2-3 seconds
I let Jiffy lube change the fluid the day before I noticed the leak. I had them run 1qt of ATF through because I had no idea when the last time the fluid was changed or if it had ever been flushed before I boughte it. I'm right at 160k miles so I figured I couldn't hurt to be safe Any ideas before I pay an arm and a leg taking it to a transmission shop? -------------------- 97 Celica GT liftback DD/ project
96 corolla back up DD |
Aug 29, 2013 - 9:06 AM
Enthusiast ![]() ![]() Joined Mar 1, '12 From iowa Currently Offline Reputation: 0 (0%) |
I would replace the axle seal on the transmission. Its only a couple bucks and very easy to do.
Btw why are you putting atf into a manual trans? |
Aug 29, 2013 - 9:59 AM
The ATF was just run through for the purpose of flushing any shavings or gunk because it's a lot cheaper than syncromesh
And thanks for the help Auto Zone doesn't have an axle seal listed on there site. Does it have a different name? This post has been edited by toyota123: Aug 29, 2013 - 10:02 AM -------------------- 97 Celica GT liftback DD/ project
Sep 1, 2013 - 12:00 AM
Enthusiast ![]() Joined Aug 31, '13 From Wyoming Currently Offline Reputation: 0 (0%) |
Output shaft seal...
http://www.oreillyauto.com/site/c/search.o...&vi=1274396 This post has been edited by Roadrash: Sep 1, 2013 - 12:05 AM |
Sep 2, 2013 - 11:40 PM
Thanks I mostly run through auto zone because of their reward program. I actually ended up getting the seal and a 24mm wrench so I can do my own fluid changes on the tranny now. Walked out the door having only paid 12 cents
Sep 3, 2013 - 12:15 AM
Very important!!!
Remember to treat that seal with a lot of care! It can be broken very easy! When installing, i suggest using a 2x4 wood and use that to slowly tap in the seal. |
Sep 3, 2013 - 8:15 AM
^^^ very good point. they are delicate. slightest nick or tear will make them leak. i grabbed a socket, a big one mind you, that the outside lip of the seal fit nicley into. then a 2x4 on the socket and some love taps in.
| Lo-Fi Version | Time is now: August 22nd, 2026 - 7:53 PM |
