Sep 10, 2013 - 1:13 PM
Enthusiast Joined Sep 10, '13 From Maryland Currently Offline Reputation: 0 (0%) |
new-to-me 99 gt convertible badly needs a clutch. i'll be doing the work myself over the next two weekends, so hopefully that'll give me enough time.
i already ordered the parts (aisin clutch kit, timken seals, sachs flywheel), along with every nut and bolt i'm probably going to break in the process. this thread is just to ask for help along the way, post pics of my work, and get yelled at for not doing it the right way i plan on tearing it apart this weekend and putting it back together next weekend. then i can get it inspected and titled. -------------------- -j
Sep 10, 2013 - 10:47 PM
Enthusiast ![]() Joined Aug 31, '13 From Wyoming Currently Offline Reputation: 0 (0%) |
Here you go man, http://bgbonline.celicatech.com/6g/ ... I just replaced mine a few weeks ago using the info here. Just hit the transmission/manual category. Its not as hard as you think =) If you have any questions, just ask.
And on that note, hit the stickies. TONS of useful info in there This post has been edited by Roadrash: Sep 10, 2013 - 10:50 PM |
Sep 11, 2013 - 7:25 AM
sweet, thanks.
i've done a clutch job before, but on my 93 pickup, so a fwd will be a bit different. few questions: -how long did the whole job take you? i've heard 6 hours to 3 days -did you break anything? (ie, what should i watch out for) -is there a pilot bearing? i haven't seen any mention of on anywhere -how high did you raise the car? -any hardware you replaced while it was apart anyway? -and anything you forgot to order? i know some of the questions might be trivial, but i couldn't find too much. maybe i'm just over-thinking it thanks again -------------------- -j
Sep 11, 2013 - 5:18 PM
sweet, thanks. i've done a clutch job before, but on my 93 pickup, so a fwd will be a bit different. few questions: -how long did the whole job take you? i've heard 6 hours to 3 days -did you break anything? (ie, what should i watch out for) -is there a pilot bearing? i haven't seen any mention of on anywhere -how high did you raise the car? -any hardware you replaced while it was apart anyway? -and anything you forgot to order? i know some of the questions might be trivial, but i couldn't find too much. maybe i'm just over-thinking it thanks again i can do a clutch in 4 hours just tabs that hold wiring that are brittle, you are in MD so expect bolts to be hell getting off no pilot bearing on FWD i raised it as high as my jack-stand will let me replace the flywheel bolts, get new ones from the dealer. they are supposed to be a one time use new gear oil, i use plain 80/90 gear oil. -------------------- 2001 Celica GT-S Turbo
Sep 11, 2013 - 6:17 PM
thanks. that helps a bunch.
new flywheel only a few bucks more than resurfacing: ![]() and the aisin clutch: ![]() flywheel bolts are on their way. if everything goes well, i might even be able to get it all done this weekend. but that's dependent on my hardware shipment This post has been edited by JuniorJoe: Sep 11, 2013 - 6:25 PM -------------------- -j
Sep 11, 2013 - 10:32 PM
It took me a good 8 hours, but it was my first FWD clutch job as well
I managed to tear my new passenger side output shaft seal, which resulted in an extra trip to town. Find yah a big socket that fits snug over the lip on the seal, then use a 2x4 and a hammer with some caress to get them in right. Yep, jacked it up as high as I could get it. Flywheel bolts, and the shaft seals in the tranny. |
Sep 12, 2013 - 7:21 AM
thanks guys. 8 hours for anyone else is 2 days for me. i'm anal about safety, so blocking, choking, and securing everything will take a bit of my time.
redline mt-90 is on its way, and flywheel bolts were ordered in the hardware order. well, looks like all my hardware will be here before saturday, so i'm hoping i can get it all done this weekend. that would be great, seeing as how it's supposed to be nice weather next week -------------------- -j
Sep 14, 2013 - 2:49 PM
help!
i don't know how to lower the tranny safely. axle shafts came out no problem all the linkages and wires are disconnected. i don't know what to call everything (i'm a truck guy, not fwd car guy), but the middle "crossmember" (two bolts in the front, holds the trans mounts) isn't coming out because the rear mount goes through it. i'll post pics here in a sec there was a great web page, all in japanese, with ~5 pages of great pictures. but now i can't find it. anyone have it? do i need to remove the "sub-frame" (holds the lower control arms)? -------------------- -j
Sep 14, 2013 - 3:32 PM
no you dont have to lower the subframe.
what you need to do is back out the trans just enough so it rotates on the input shaft. then rotate it around the rear engine mount -------------------- 2001 Celica GT-S Turbo
Sep 14, 2013 - 3:48 PM
thank you so much!
Sep 14, 2013 - 4:47 PM
...aaaaand the trans is out!
tomorrow: replace the clutch, and do it all again, in reverse. man, that's a "light" transmission... -------------------- -j
Sep 14, 2013 - 8:13 PM
![]() the rest of the clutch ![]() the old (first project tomorrow) ![]() the mount that gave me issues. getting it back in will be... "fun" ![]() and the clutch through the pressure plate ![]() thats all i felt like photographing today. tomorrow i want to get the trans bolted back up, at least -------------------- -j
Sep 15, 2013 - 4:19 PM
ha ha ha, i have that exact same green jack
Sep 17, 2013 - 8:25 AM
got everything done this weekend. it was a pita getting the splines lined up (trans to engine), but it finally went.
thanks for all the help, guys. my next investment will probably be an engine hoist... final pics coming soon -------------------- -j
| Lo-Fi Version | Time is now: September 11th, 2026 - 9:20 PM |
