> idling rough when cold or fully warmed up, idling rough when cold or fully warmed up
post Sep 16, 2013 - 5:58 PM
codybellenbaum
Joined Sep 16, '13
From los angeles, CA
So about two weeks ago i drove 800 miles because i moved to LA. i had to pull a trailer weighing about 2000 pounds all was going well until i went over the grape vine on i-5 cracked the radiator somewhere on the pass then it overheated so i pulled over in la and got towed to my destination (10 miles away) bought a new radiator put it in no problem. took it for a test drive and it ran horrible like it wasnt running on all cylinders. so while it was running i pulled off one wire at a time to see which one didnt make a difference.. i believe the car got so hot it fried all the plug wires because 2/4 litterally ripped in half while i was checking them. so i ran to a part store got new plugs wires and cap and rotor. the car ran great for a day or 2 then one morning it ran the same as it did before i gave it the tune up, but after 10 seconds it ran perfect again. now it does this every time the car is started cold. a few days after that i noticed when its fully warm it runs similar to cold... running rough at low rpms but more subtle when its warm than when its cold. Does anyone know what could be causing this kind of behavior from the engine?
PS. Also the check engine light came on when it over heated the first time when the radiator cracked. i keep forgetting to reset the light. i dont think it has anything to do with the current problem but im not sure because it did happen around the same time..
Replies (1 - 8)
post Sep 16, 2013 - 6:34 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
What year is the car? Check to see what code it is throwing.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 16, 2013 - 11:12 PM
Check compression. 2000lbs is WAY more trailer than a Celica can tow, that's almost as much as the car weighs!
post Sep 17, 2013 - 2:47 AM
rentaspace
Joined Sep 23, '12
From Australia
Mine has a rough idle as well when it is cold... When I use 98 fuel it almost disappears, but sometimes not...
I'm doing a full service on the weekend so if that helps it for me then I will report back here with everything I have changed smile.gif
post Sep 17, 2013 - 11:50 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
First I'd do a cylinder balance test, easiest way to do it is to pull the spark plug wires one by one while the engine is running. Each time you pull a plug-wire the rpms should drop so if one cylinder doesnt drop the rpms like the others you know this cylinder is misfiring. If all 4 cylinders are even than we can go from there.
Also, keep in mind that the throttlebody is connected to the coolant system you yoou need to insure that all the airbubbles are out of the cooling system or it might not idle properly.
post Sep 20, 2013 - 3:22 AM
codybellenbaum
Joined Sep 16, '13
sorry ive been busy and havent been able to check my thread.. anyways
@richee3 it is a 96 gt with the 2.2L engine. how do i check which code it is?
@bitter i cant check compression or any thing with pressure because all of my gauges and Nice tools are back at home... 800 miles away lol
@rentaspace thanks! keep me posted
@special edy i know what that is because thats how i destroyed my plug wires the first time! haha but i will try that again when i feel the miss.
post Sep 20, 2013 - 4:56 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
You'll need an OBDII scanner. The plug for our and most cars are under the steering wheel just above the pedals. Them scanners are pricey. I bought mine for $60 and it's the BASIC scanner too. If you're lucky. A local shop will scan your car for free.
post Sep 20, 2013 - 5:39 AM
richee3
Joined Jun 29, '08
From Denver
Currently Online
Autozone/Advance Auto Parts will scan it for free.
1998 Celica GT-
BEAMS Swapped.
post Sep 21, 2013 - 9:29 PM
codybellenbaum
Joined Sep 16, '13
QUOTE (richee3 @ Sep 20, 2013 - 5:39 AM) *
i went to autozones and asked them if they could do that when the light first came on and they said they dont do that anymore. but i disconected the battery today because i needed it out of the way, and i was hoping it would reset. the check engine light never came back on. so that reassures my thought that it happened when the first problem occured that i already fixed
Lo-Fi Version Time is now: July 29th, 2026 - 11:42 PM
