> code 14!!! help!!
post Sep 18, 2013 - 4:03 AM
gt4joel
Joined Aug 29, '13
From australia
ive got a st 205 gt4 and one of the codes its spewing at me is code 14.
pardon my ignorance but how do I fix it!
its got something to do with the ignitor. has anyone had this problem and what do you replace\fix to get it going again.
thanks
Replies (1 - 3)
post Sep 18, 2013 - 10:00 AM
isnt code 14 for the intercooler water pump? im sure this has been covered on the site. please search
post Sep 18, 2013 - 10:09 AM
Malek
Joined Jan 26, '09
From Los Angeles
Code 54 is for the intercooler.
code 14 = Check igniter, ignition coil, ECU and IGT wire to igniter. Can be caused by wire feed into the coil. The IGF signal is fed back to the ECU to inform the ECU that the igniter is "ok"
Straight copied and pasted that from another forum. Some fixes are replace ignitor and coil or it could be a faulty wire on the ecu.
post Sep 18, 2013 - 10:21 AM
^^^ ah yes 54. and your answer to 14 sounds perfect!
Lo-Fi Version Time is now: September 11th, 2026 - 11:37 PM
