> Seeking distributor info: 95 Celica, 7A-FE
post Sep 18, 2013 - 3:10 PM
ActionClaw
Joined Jul 29, '08
From N. E. Ohio
I'd appreciate if anyone could please direct me to where one might find information regarding the distributor used in a 1995 Toyota Celica, 7A-FE engine ...or similar used in other years or models.
Specifically, I'd like information about
the internal components/circuit path and/or
how to test/troubleshoot
either while connected or removed from circuit.
Any info, any format would be helpful and appreciated.
As usual, Thanks for any assistance.
Replies (1 - 1)
post Sep 25, 2013 - 1:37 AM
ActionClaw
Joined Jul 29, '08
From N. E. Ohio
I was able to locate some useful info on the distributor, individual internal components and their troubleshooting/testing procedures. (I'd like to upload it here for others' future use but don't see how it's possible to do so. If it's not, consider it a suggestion. In the meantime, I'll try to later post the links here.)
What I am still seeking is information about Ignition Control Module and if possible, any data or testing procedures.
The Ignition Control Module has 5 (unidentified) points of contact:
3 screw terminals (2 on one end, 1 on the other)
2 wire leads
I believe the 2 wire leads are it's output, connected to the coil primary.
Of the others, I believe at least one comes from the pick up coil
I'd guess one connects to the ECU (feeds to or is fed by?)
..the other?
Is it possible to, either in circuit or removed, test an ignition module using common, ordinary test equipment?
Lo-Fi Version Time is now: August 31st, 2026 - 10:50 AM
