Sep 30, 2013 - 11:51 AM
Enthusiast ![]() Joined Sep 16, '13 From Grand Rapids, MI USA Currently Offline Reputation: 1 (100%) |
Found an awesome set of rims and tires for my '99 GT ragtop. They are from an Chevy HHR (not stock) and are 5x110.
http://grandrapids.craigslist.org/pts/4045494385.html The tires are 225/40/18. According to the tire calculator on tires.com, this is 1.65 inches taller than my 195/55/15s. So only .8 inches taller in every direction. I will be going 69 mph when my speedo says 65. Isn't 205/50/15 supposed to the correct stock size? If so, the height diff will only be 1.21 inches, .6 in each direction, going 68 mph when the speedo says 65. The bite is the width... I will screw up the technical terms, so I will describe in layman's terms. The wheels are 9 inches wide. However. where the inside of the wheel rests against the caliber is at least one inch deeper than my stock rims. There is a spacer that convers 5x100 to 5x110. It is about 1 inch wide. With those, the wheel sticks out 2 inches wider than stock. The equivalent of a 7 inch wheel on the inside. Correct? For the bagillion dollar question... could this work? I believe my stock rims are only 6.5 (?) inches wide. Technically, it looks like the rim will only be .5 inches wider on the inside. Will two inches stick out too far from the fenders? I would like the fenders more filled out, but not too far. Thank for any assistance!!! This post has been edited by GTMike: Oct 1, 2013 - 12:15 PM -------------------- '99 Triple Black GT Convertible
Check out the "Michigan Toyota Scion and Lexus Crew" on Facebook. |
Sep 30, 2013 - 12:15 PM
![]() Enthusiast ![]() ![]() Joined Jul 17, '12 From Slovenia Currently Offline Reputation: 0 (0%) |
Correct stock size is 205/55R15 or 205/50R16, here is a great online calculator for tire/wheel dimensions. I don't see anywhere the offset (ET) value, so I guess nobody can tell you if it will fit.
The tires seems to be 33 mm taller, what might fit without rolling the fenders (if you got stock suspension), but you'll notice quite a different handling, especially with 18"... But since I don't actually have much experience with this, don't take my word -------------------- |
Sep 30, 2013 - 12:18 PM
Found a tape measure and did it the old fashioned way. The fender sticks out 1 inch wider than the stock rim. 2 inches would look terrible if my calculations are correct.
Also, 25 was stamped in the inside. That is the closest I could find to an offset. This post has been edited by GTMike: Sep 30, 2013 - 1:45 PM -------------------- '99 Triple Black GT Convertible
Sep 30, 2013 - 10:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) |
you cannot just measure with a tape measure from what you have now, because the new specs and offset of the new wheel is different. Its best to use a tyre calculator to see the measurement differences on the outer and inner clearances. basically even if you had the same wheel width and different offsets, its already different, how much more with different widths and offset at the same time.
| Lo-Fi Version | Time is now: August 26th, 2026 - 8:12 AM |
