Nov 20, 2013 - 1:25 AM
Enthusiast ![]() Joined Jul 15, '07 From Mexico Currently Offline Reputation: 2 (100%) |
I have my brother´s celica with the technician , he told to us that two injectors are clogged, but he dont have any idea about how to remove them since he is computer/scanner specialist
Thank you!! |
Nov 20, 2013 - 5:29 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
It's easy, but might be a little hard for someone who doesn't have mechanical aptitude.
1. Remove the valve cover, which requires taking off four 30mm nuts (spark plug tube nuts). 2. You'll see the fuel rail behind the cams. There's two 12mm bolts holding it onto the head. Remove them. You should now be able to pull off the rail with all four injectors. However, you MUST depressurize the fuel system before attempting this, as you WILL spray gasoline all over your engine, hands, arms and face if you don't. -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Nov 21, 2013 - 1:37 AM
It's easy, but might be a little hard for someone who doesn't have mechanical aptitude. 1. Remove the valve cover, which requires taking off four 30mm nuts (spark plug tube nuts). 2. You'll see the fuel rail behind the cams. There's two 12mm bolts holding it onto the head. Remove them. You should now be able to pull off the rail with all four injectors. However, you MUST depressurize the fuel system before attempting this, as you WILL spray gasoline all over your engine, hands, arms and face if you don't. Thank you! i have followed your instructions and it was quiet easy. |
Nov 21, 2013 - 6:39 AM
It's easy, but might be a little hard for someone who doesn't have mechanical aptitude. 1. Remove the valve cover, which requires taking off four 30mm nuts (spark plug tube nuts). 2. You'll see the fuel rail behind the cams. There's two 12mm bolts holding it onto the head. Remove them. You should now be able to pull off the rail with all four injectors. However, you MUST depressurize the fuel system before attempting this, as you WILL spray gasoline all over your engine, hands, arms and face if you don't. Thank you! i have followed your instructions and it was quiet easy. ¡Cómo no! You're welcome. -------------------- 1993 Celica GT Coupe - sold
Nov 26, 2013 - 7:45 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) |
one of the crappy reasons with the 5s
| Lo-Fi Version | Time is now: September 7th, 2026 - 11:34 AM |
