Nov 23, 2013 - 10:07 AM
Enthusiast Joined Mar 3, '13 From NH Currently Offline Reputation: 0 (0%) |
So my buddy ripped off all plug wires and not one at a time. Tried hookinng them up as looking down on engine 1234 then match on the cap. Does not work. If i do it as 4321 it works?
Nov 23, 2013 - 10:22 AM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
the distributor cap should indicate the firing order on it. and I believe it's 1-3-4-2 starting from bottom left and going clockwise.
Nov 23, 2013 - 12:42 PM
Did that and don't work.
Nov 23, 2013 - 1:18 PM
Nov 23, 2013 - 2:02 PM
You don't need to know the firing order. You just match up the numbers from left to right with what's printed on the distributor cap. 1234. easy stuff.
Then make sure the middle wire on the distributor cap is going to your coil. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Nov 25, 2013 - 5:02 PM
I will give that a shot in the morning. Thanks
| Lo-Fi Version | Time is now: September 7th, 2026 - 11:34 AM |
