Jan 12, 2014 - 2:26 PM
![]() Enthusiast ![]() ![]() Joined Apr 24, '13 From Tomball, TX Currently Offline Reputation: 3 (100%) |
I'm looking for
-3sgte exhaust manifold -3sgte oil pan -3sgte oil/water coolant lines to and from turbo w/ oil drain hose -3sgte intercooler w/ fan -3sgte turbo to intercooler pipe -3sgte 2 bar map sensor part #23250-70080 -MkIII Supra NA injectors light green tops -decent cheapish boost gauge will probably be adding more but this is what i need as of this moment. -------------------- "As a professor of science, I assure you we did, in fact, evolve from filthy monkey-men." -Prof. Farnsworth
Jan 12, 2014 - 9:34 PM
Enthusiast ![]() ![]() Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
I'm looking for -3sgte exhaust manifold -3sgte oil pan -3sgte oil/water coolant lines to and from turbo w/ oil drain hose -3sgte intercooler w/ fan -3sgte turbo to intercooler pipe -3sgte 2 bar map sensor part #23250-70080 -MkIII Supra NA injectors light green tops -decent cheapish boost gauge will probably be adding more but this is what i need as of this moment. I was going to turbo my 5s but ended up not doing it. So i've got the following laying in a box somewhere in my garage: Manifold, oil pan, oil/coolant hard line, and the MAP sensor. I can dig it out and shoot you some PICs after work. -------------------- ![]() |
| Lo-Fi Version | Time is now: August 22nd, 2026 - 4:55 PM |
