> 3sgte rear main seal, Leaking after first oil change
post Mar 11, 2014 - 9:54 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
I rebuilt my gen ii 3sgte over the fall. New Toyota oem gaskets, machine work, new turbo etc. assembled it with engine lube and ran Mobil conventional 10-30 for the first 1500 miles. I recently did a Mobil synthetic 10-30 oil change and oil has been leaking from I between the engine and Trans (very sizable about of oil leaks when car is running). What caused this leakage? I would think if the gasket was seated incorrectly it would leak from day one. Any input is appreciated!
Replies (1 - 7)
post Mar 11, 2014 - 10:26 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
oh boy...
エキサイティングカーレーシングチーム!
post Mar 11, 2014 - 10:45 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
Possibility that crankcase pressure was the cause? Maybe I should do a catch can?
post Mar 11, 2014 - 6:41 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
false alarm! it was the passenger axle seal. that thing leaks like a champ!
post Mar 12, 2014 - 9:58 AM
QUOTE (garin @ Mar 11, 2014 - 11:45 AM) *
A catch can doesn't relieve pressure. It just catches the oil that comes out and prevents it from going back into your intake, which can sometimes cause the car to smoke on hard acceleration.
Anyway, glad you figured it out! Hope to see the car again in person sometime soon!
post Mar 12, 2014 - 12:28 PM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
a nice breather filter and a cheap catchcan you can dump into something so you dont spill oil and water everywhere
post Mar 12, 2014 - 1:33 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Get the Timkin seal from autozone. The borg-warner or whatever brand has a lip sort of like a dust seal on it that makes it hard to hammer in. Especially on the passenger side!
post Mar 12, 2014 - 2:26 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
I ended up buying Toyota oem axle seals... I work at a dealership. I did buy a catch can too. I decided on a mishimoto baffled can. It should be here Friday.
Lo-Fi Version Time is now: August 31st, 2026 - 7:34 AM
