> HELP.. RED TOP BEAMS, 3sge 2.0 GT 94 swapped out with a BEAMS
post Mar 21, 2014 - 12:19 PM
NICOGP
Joined Mar 21, '14
From Denmark
Hi everyone, I'm new here on forum.
I have swapped out my old engine and I have put in a red top beams engine.
I tried starting it today but it didn't fire, and I saw a topic about connecting the red/black wire with the black at the EA1 plug. It worked and it started and died 2 sekunds after. First of I thought it was vacuum problem coursing it to die out, because if I gave it some revs I could keep it alive. By some reason I tried disconnect the airflow sensor, and now it runs "perfect" (Engine failure light on). I'm I missing a wire to connect or something, or is it a new air flow sensor?
It gets +B and earth, and I have tested the other 3 wires and it seems like they give some signal
Replies (1 - 8)
post Mar 21, 2014 - 1:15 PM
richee3
Joined Jun 29, '08
From Denver
We need a little more information from you. What intake are you using? Have you tried cleaning the MAF? Be sure to pull the codes to see what codes it's throwing. Then try resetting the ECU and plugging the MAF back in. Try keeping it running with the MAF plugged in until it's warmed up. Then try pulling codes again to see what you get.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 21, 2014 - 2:06 PM
NICOGP
Joined Mar 21, '14
From Denmark
QUOTE (richee3 @ Mar 21, 2014 - 2:15 PM) *
Volt between EVG - VG when with ignition on II = 0,99V
Volt between EVG - VG when the engine is running = 0,99V-1,04V (Data 1.0V-1.5V)
I'm using a custom made intake, but I'm using the old part of the airbox with the sensor.
MAF=Airflow sensor?
It's not easy to keep the engine running with the airflow sensor plugged, but I'll give it a shot tomorrow.
How would you clean it?
Thanks
post Mar 21, 2014 - 3:47 PM
richee3
Joined Jun 29, '08
From Denver
If it's available near you. As long as the MAF (mass air flow sensor) is in the OEM MAF housing, you should be good. It's a very, very sensitive MAF that needs to be in that housing so it gets an accurate reading, otherwise the engine won't run properly, but it sounds like your setup should work. DO you have a picture of your intake setup?
1998 Celica GT-
BEAMS Swapped.
post Mar 21, 2014 - 7:18 PM
MAF = Mass Air Flow sensor
pics will help. Do you have an 02 sensor hooked up ?
post Mar 22, 2014 - 1:48 AM
NICOGP
Joined Mar 21, '14
From Denmark
I'll get some pictures as soon as possible, I'll try a couple of shops on my way there.
Thanks again
post Mar 22, 2014 - 4:35 AM
NICOGP
Joined Mar 21, '14
From Denmark
I have been in all the car shops on my way and no one had that cleaner, can I use something else instead?
post Mar 22, 2014 - 4:41 AM
NICOGP
Joined Mar 21, '14
From Denmark
The o2 sensor is connected, I plugged the old one on the new wiring harness
Can any of you confirm this wiring?
AIRFLOW SENSOR WIRING
ECU CODE : D16 (RED/BLACK) TO POSITION 1 ON THE PLUG (+B)
ECU CODE : B1(YELLOW/RED) TO POSITION 2 ON THE PLUG (EVG SENSOR)
ECU CODE : B11 (BLUE/BLACK) TO POSITION 3 ON THE PLUG (VG METER)
ECU CODE : B22 (YELLOW/BLACK) TO POSITION 4 ON THE PLUG (THA TEMP)
ECU CODE : B18 (BRAUN) TO POSITION 5 ON THE PLUG (EARTH)
post Mar 23, 2014 - 4:09 AM
NICOGP
Joined Mar 21, '14
From Denmark
I tried cleaning the MAF and it didn't help, not enough to feel any differens.
Shouldn't I just order a new one tomorrow?
Lo-Fi Version Time is now: August 23rd, 2026 - 12:22 AM
