Jun 29, 2014 - 12:50 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
installed an avcr today. everything seems to be wired properly. throttle reads open and closed on the unit, however the engine flutters at 2000 rpms. I'm not sure what is wrong. air fuel is rich and vacuum doesn't really move from 22 in/hg. any input is appreciated
Jun 30, 2014 - 2:22 PM
AVCR is a boost controller, not a tuner like the SAFC.
Jun 30, 2014 - 3:39 PM
I am very well aware of this! That is why I am asking. My car seems to be in a limp mode after the install.
Jun 30, 2014 - 3:43 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 25, '08 From England Currently Offline Reputation: 1 (100%) |
What settings did you use?
Jun 30, 2014 - 6:32 PM
Didn't even get that far. I plumped it as follow.
1. Turbo compressor wheel to "no" port on solenoid 2. Wastegate to "com" port 3. Plugged the wastegate to vsv port 4. Jumped the green boost solenoid (back of manifold) on the vsv system 5. Apexi map sensor is tapped into boost gauge line on intake manifold Wiring 1. Red is power into ignition fuse 2. Green and black to body ground 3. Purple into injector 1 on the ecu (plug e4 pin 12) 4. White to speed sensor on the ecu (plug e6 pin 9) 5. Gray to vta (plug e5 pin11) pink and black; goes to tps Did I do anything wrong with install? -------------------- |
Jul 1, 2014 - 12:27 AM
Everything with the install looks okay apart from possibly the earth, they have to go close together on an earth wire to the ECU, something like within two inches of each other but not soldered together, and pretty close to the actual ECU.......if that's how you did it then that's fine.
But, you need to set it up before you run the car. I don't know if you can follow this link. http://www.gt4oc.net/forums/download/file.php?id=19999 I will try and copy And paste it here later on today if nobody else does, it will give you all the settings you need for a basic set up, it will need further tweaking to get it perfect for your car etc but it's a good start. This post has been edited by Nial: Jul 1, 2014 - 12:30 AM -------------------- |
Jul 1, 2014 - 5:26 AM
Everything with the install looks okay apart from possibly the earth, they have to go close together on an earth wire to the ECU, something like within two inches of each other but not soldered together, and pretty close to the actual ECU.......if that's how you did it then that's fine. But, you need to set it up before you run the car. I don't know if you can follow this link. http://www.gt4oc.net/forums/download/file.php?id=19999 I will try and copy And paste it here later on today if nobody else does, it will give you all the settings you need for a basic set up, it will need further tweaking to get it perfect for your car etc but it's a good start. i might have to look over my grounds... and please do copy that link here! -------------------- |
Jul 1, 2014 - 7:10 AM
These should get you underway, they will need adjusting to suit your car.
Apex-i AVC-R settings for 0.9 Bar and 1.1 bar BASIC SETTINGS Setting [A] 0.9 Bar Boost /Duty Cycle Bst = 0.90kg/cm2 Duty = 52% NE Point NE1 = 3000 NE2 = 3500 NE3 = 4000 NE4 = 4500 NE5 = 5000 NE6 = 5500 NE7 = 6000 NE8 = 6500 F/B Speed 1S = 5 2N = 5 3R = 5 4T = 5 5T = 5 Learn Gear 1S = x 2N = x 3R = x 4T = x 5T = x Start Duty 1st = 5% 2nd = 1% Setting [B] 1.1 Bar Boost /Duty Cycle Bst = 1.10kg/cm2 Duty = 60% NE Point NE1 = 3000 NE2 = 3500 NE3 = 4000 NE4 = 4500 NE5 = 5000 NE6 = 5500 NE7 = 6000 NE8 = 6500 F/B Speed 1S = 5 2N = 5 3R = 5 4T = 5 5T = 5 Learn Gear 1S = x 2N = x 3R = x 4T = x 5T = x Start Duty 1st = 6% 2nd = 2% Etc settings Car Select Cyl = 4 Spd = 5 Throttle = / (arrow pointing up to the right) Sensor Select Number one (1) Gear Jdge 1st = 120 2nd = 075 3rd = 050 4th = 035 5th = 025 N/S = 255 Graph Scale BS = 2.0kg/cm2 Ne = 8000 RPM Sp = 300km/h Monitor 2 Channel 1 Bst 2 Rev You can set the Monitor to whatever you want and display any information you choose from 1 to 4 different types of information -------------------- |
Jul 1, 2014 - 8:39 AM
I didn't see a "spd 5" option... Any words of wisdom? This is for a gen ii.
Jul 1, 2014 - 8:49 AM
If there isn't an option for it, then I guess you can leave it.
Jul 1, 2014 - 8:57 AM
If there isn't an option for it, then I guess you can leave it. There is a spd 2,4,6 I think. Thanks for the help I'll keep you pisted -------------------- |
Jul 1, 2014 - 11:09 AM
Good stuff, I look forward to your next pist!
Aug 23, 2014 - 8:50 PM
Everything seems to read and respond properly. The unit loses memory after the car is shut off. Might need to tap into another power source...
Aug 24, 2014 - 2:36 AM
Everything seems to read and respond properly. The unit loses memory after the car is shut off. Might need to tap into another power source... It shouldn't! Mine keeps it's memory even after the battery has been completely removed for servicing.? -------------------- |
Aug 24, 2014 - 10:14 AM
To save the setting I must go to the "7. Initialize" and select "yes" with the next button correct?
Aug 24, 2014 - 11:25 AM
To save the setting I must go to the "7. Initialize" and select "yes" with the next button correct? Can't remember, it's a while since I set one up....try it and see what happens? -------------------- |
Aug 24, 2014 - 1:43 PM
figured it out! "initialize yes" resets it to factory settings. thanks nail for the numbers i think I'm running around 12 lbs now.
Aug 24, 2014 - 4:23 PM
No bother bud, glad it's all fixed and working.
| Lo-Fi Version | Time is now: May 17th, 2026 - 3:47 PM |
