> Walbro fuel pump just got very loud!
post Jul 2, 2014 - 9:27 PM
match220
Joined May 13, '06
From Kaimuki, HI
So my pump got ridiculously loud yesterday, then today I started it and it was back down to its normal sound. Normally it runs at a noticeable volume, but yesterday I could hear it very loud over my car exhaust. It only has 7k miles on it, I doubt it would be going out already, but that's possible. I used the GSS342 for the Mazda mx3. The car seemed to be idling strangely, but still accelerated fine, and my voltage output was at the normal 13s according to my gauge. I didn't check the voltage at the pump though. Could it have been a restriction or ventilation issue?
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
Replies (1 - 10)
post Jul 2, 2014 - 9:33 PM
mkernz22
Joined May 10, '10
From MA
Replace the strainer, my friend had the same issues in his gst
post Jul 2, 2014 - 9:43 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (mkernz22 @ Jul 2, 2014 - 4:33 PM) *
ah..ok. That kinda makes sense. The car sat for 4 years while I was building up the 3s to go in it. I drained the tank, but there could have still be sediment in it.
-Jay
post Jul 2, 2014 - 9:53 PM
Box
Joined Feb 23, '12
From Warrior, AL
Did you run it fairly low on fuel by chance? It wouldn't hurt to change the strainer and fuel filter if you haven't yet.
This post has been edited by Box: Jul 2, 2014 - 9:54 PM
2001 Miata LS 5-speed
post Jul 2, 2014 - 10:22 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Box @ Jul 2, 2014 - 4:53 PM) *
I never let it get below E. When it hits E I'll fill it up to half. There are a couple gallons below E, but I understand that sediment floats on the gas, and a low tank will suck it up. I would keep it full but my tank leaks when I fill it up all the way, so I keep it between half and E.
-Jay
post Jul 2, 2014 - 10:41 PM
Box
Joined Feb 23, '12
From Warrior, AL
Leaks, that's not good. redface.gif It's also letting fuel evaporate which will cause deposits to form faster, that and it probably isn't forming a vacuumed seal like it should either. When you remove the cap it should make a psshhh sound.
I also ran mine from around a half to around a quarter or so, just to keep as fresh as fuel as possible. Though it's a little more of a pain that just topping it off and letting it go from there.
This post has been edited by Box: Jul 2, 2014 - 10:42 PM
post Jul 2, 2014 - 10:58 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Box @ Jul 2, 2014 - 5:41 PM) *
so I guess I have to drop the tank and find that leak then.
-Jay
post Jul 2, 2014 - 11:48 PM
Box
Joined Feb 23, '12
From Warrior, AL
Could be the filler neck that's the culprit. If you were to fill it up to where it'd normally leak you might be able to see it. Permatex makes a fuel tank repair kit I believe.
post Jul 2, 2014 - 11:52 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Box @ Jul 2, 2014 - 6:48 PM) *
there is also a gasket around the filler neck if I recall correctly. I'm pretty sure I removed the filler neck when I dropped the tank last time to dump the old fuel. So it might be that I need a new gasket and shouldn't have reused the old one.
My plan is to fill it up all the way to where it leaks, since it's been about a year since I did it will clean off whatever dust is around that area. I haven't had a lot of luck with tank repair kits. They are made more for punctures, I tried all of them on a friends tank and none worked longer than a week. Silicone gasket maker might do the trick if I can find a fuel grade one.
This post has been edited by match220: Jul 3, 2014 - 12:04 AM
-Jay
post Jul 3, 2014 - 12:15 AM
Box
Joined Feb 23, '12
From Warrior, AL
Hopefully it's something simple like that. Being in Hawaii I really don't see how it could be because of rust or what have you.
post Jul 3, 2014 - 12:32 AM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Box @ Jul 2, 2014 - 7:15 PM) *
I know it isn't from rust. I had the tank out last year and it was very rust free. I should check the fuel pump mount first since it's easy to access from beneath the seat. I hope that's all it is.
-Jay
Lo-Fi Version Time is now: August 25th, 2026 - 2:05 PM
