> changing lights on dash, can i change the stock green to blue
post Feb 6, 2004 - 10:02 PM
belizecelica
Joined Feb 4, '04
From Tampa
I am wondering if I can change th stock lights in the dash behing AC and heater contorls from the green to another colour like blue or red? Is it a simple swicth of the bulbs?? If so does anyone know the number bulbs installed??
Replies (1 - 9)
post Feb 6, 2004 - 11:04 PM
Cody
Joined Dec 11, '02
From Sioux Falls, SD, USA
They're tiny LEDs, and require soldiering...it's not simple, and best left to someone that knows a lot about doing it. Someone around here was doing it for a fee a while back.
post Feb 7, 2004 - 4:21 PM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
yes, it is doable, i changed them last week..
post Feb 8, 2004 - 4:02 PM
BenMMellor
Joined Dec 24, '02
From Wirral, UK
QUOTE (kingpreetham @ Feb 7, 2004 - 2:21 PM)
details please ?
is yours a climate control setup.. mines a manual setup to change temp. I thought there were 2 tyep 194 bulbs inside the unit and then each button has it's own LED ?
post Feb 8, 2004 - 9:22 PM
yep
Joined Jun 24, '03
From MD
Do a search, there was a post a few months ago that had a picture of the climate control with the face removed. It had some usefull information.
post Feb 9, 2004 - 10:53 AM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
there are 3 bulbs and one LED for each button....
Its not too hard to replace them, just need to find the right bulbs...there was a post a few months earlier, should give you all the details....mine is a manual control...
post Feb 28, 2004 - 5:22 PM
BenMMellor
Joined Dec 24, '02
From Wirral, UK
I was tinkering with my heater control cluster today.. it was a bit of a twat to get out - mainly the manual contrl cables.. but I did get access to the 3 bulbs in it.. AND may have found replacements !!
Having got the unit apart i went onto t'internet to find replacements and found these >>>
http://www.superbrightleds.com/1157.htm
type 74 bulbs on a base..
Instrument Cluster and Gauge Backlights
Twist-Lock type instrument LED bulbs consist of a T 1 1/2 (#73/74) miniature LED bulb plugged into a twist-lock socket base. LEDS have wide viewing angle.
Available with White Blue Green Red and Amber LED
Overall length: 21mm Extends into cluster: 14mm
needless to say along with a few other bits of Autoillumination.com (I bought from there before i found this site) I have got $50 worth of bulbs being sent o min ein the UK as there's f'all like these available in the uk !
post Feb 29, 2004 - 7:50 PM
Rjb23
Joined Feb 8, '04
From KY
Could someone post a how to article on this. I would like to know how to do it, I wanna change the color of the led's in my climate control. So it matches my radio and indiglo gauges.
post Mar 1, 2004 - 3:03 AM
BenMMellor
Joined Dec 24, '02
From Wirral, UK
changing the actual LED's may be a bugger to do - I spoke to my uncle who designs electronic cicuitry and the like, his advice was that for the time and potential hassle of changing the LED, a better option was to use some stage lighting gel over the LED window to change the colour.
Someone has posted a thread on the work they had to do to change the LED's already but getting the right ones and the resistors was taking time and you had to order a large amount when you only needed a handful of components.
post Mar 1, 2004 - 3:54 AM
Rjb23
Joined Feb 8, '04
From KY
I found a thread where someone changed all their led's to red. Here it is, got the led's and resistors from radio shack.
http://www.6gc.net/forums/index.php?showto...climate+control
Lo-Fi Version Time is now: September 12th, 2026 - 8:58 PM
