> Grinding in third gear., Mainly when down shifting.
post Jul 16, 2014 - 12:20 PM
TClifton91
Joined May 13, '14
From Savannah, GA
So I've been having a problem with third gear. When shifting through gears some times 3rd grinds when going from 2nd to 3rd. But when down shifting it grinds every time, 4th to 3rd. Anyone had this problem or know what it could be?
As always thanks for any help!
-T
Replies (1 - 26)
post Jul 16, 2014 - 12:24 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
I had the same issue.
Most likely the syncro's are dying, seems to be common for the 3rd gear. You can try changing out your transaxle oil to see if that helps.
post Jul 16, 2014 - 12:29 PM
TClifton91
Joined May 13, '14
From Savannah, GA
QUOTE (KAOS @ Jul 16, 2014 - 12:24 PM) *
So is that something the average person could do or would you recommend taking it to a shop? Always been pretty good with my hands and figuring stuff out. But with this I wouldn't even know where to begin.
Thanks
post Jul 16, 2014 - 12:35 PM
KAOS
Joined Apr 18, '06
Its pretty straight forward. Check the stickies, they always have the most useful information. wink.gif
http://www.6gc.net/forums/index.php?showtopic=37397
^^ its for changing the ATX (automatic) transaxle fluid, but the procedure for MTX is pretty much the same.
post Jul 16, 2014 - 2:04 PM
Box
Joined Feb 23, '12
From Warrior, AL
It's a common occurrence with the Toyota S and C series transmissions. Long story short get 3 quarts of oil, 2 parts being 75W-90 GL-4(will have to get online probably) and 1 part being Pennzoil Synchromesh. Should help alleviate the issue if not cure it, just depends on how bad the synchronizer is.
This post has been edited by Box: Jul 16, 2014 - 2:49 PM
2001 Miata LS 5-speed
post Jul 16, 2014 - 2:09 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (TClifton91 @ Jul 16, 2014 - 12:29 PM) *
Thanks
You need a rather large socket to remove the drain plug and fill plug, it may have been a 22mm on mine. First step is to remove the drain plug on the lower driverside of the transaxle, directly under the driverside cv axle shaft. Once you have drained all the fluid, you need to reinstall the drain plug, I dont know the torque spec off the top of my head but its fairly tight.
Remove the upper plug, it is on the front of the transmission, somewhat on the underside facing downwards at a slight angle. It is the same size as the drain plug. The ttransaxle will take exactly 2.7 quarts of 75-90W (I think 75-90) gear oil, but everyone suggests Pennzoil Synchromesh Fluid in this weight. The Pennzoil is known to fix third gear grinding in our transmissions. If the car is on a perfectly flat surface, 2.7 quarts will bring the fluid EXACTLY level with the drain plug hole, so that if you were to put 2.8 quarts for example, .1 quart would come spilling out.
This is all for the GT, I dont know about the ST 5spd
post Jul 16, 2014 - 2:39 PM
TClifton91
Joined May 13, '14
From Savannah, GA
Thanks for all the great info guys wink.gif. I will be tackling this over the weekend, will let you know how it goes and if it fixes the problem.
post Jul 16, 2014 - 2:53 PM
Box
Joined Feb 23, '12
From Warrior, AL
This is the cheapest GL-4 I came across: http://www.summitracing.com/parts/bpo-023-7729/overview/ Worked well, added Synchromesh later and it helped even more. Two quarts of the Brad Penn with a quart of Synchromesh and you're good to go. If you really love your car supposedly the Motorcraft GL-4 is pretty much the best thing you can put into your gearbox, it's really popular with the Miata crowd. It's also three times the price of the above mentioned.
post Jul 16, 2014 - 9:18 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
https://www.youtube.com/watch?v=aAWxZRuBXtw
there is some good demo videos on youtube of how a transmission works which will help you understand how the synchronizer works. the different(more expensive) gear oil will create more friction for the little drum to grab on to. and having somebody actually take it apart and replace stuff would be really pricey.
The little trick I use on mine basically uses the synchronizer from second gear to slow it down like this: say you're in 4th or 5th and you want to shift down to third. push in the clutch and then move the stick to the second gear spot but don't go all the way in you just need to hold it in that spot for a moment, and Then push it up into third and it won't crunch at all, now let out the clutch. Assuming you're not doing some kind of street racing where you'd need to shift down much quicker than that it really only takes a couple seconds to do. if you check out the vids of how the synchronizer works you'll understand better that we are just using the drum from second gear to slow the gear down so that it wont crunch in 3rd, most likely the drum/synchronizer for 3rd has been used hard so many times that it has worn away slightly and no longer grips like it should.
I run all 2.7 qts of Penzoil Synchronomesh in mine (the bottle says it was made for Chryslers), and other people have said they got even better results with Redline MT80 which is about $20 a quart. but I'm content enough with the results I've gotten from my little trick and don't feel the need to change the oil again. btw my drain and fill plugs were pretty rounded and I couldn't get them off with a regular 12 point so I went to Sears and got a 6 point box end for it, and I think I couldn't find the metric 22mm one but the 15/16" was the same size. then I went to Toyota and bought two new plugs. and you're going to need a little oil pump to refill it, you'll never be able to just tip the bottle up and pour it in to the fill hole.
This post has been edited by VavAlephVav: Jul 16, 2014 - 9:26 PM
Bust a Deal; Face the Wheel.
post Jul 16, 2014 - 9:22 PM
Box
Joined Feb 23, '12
From Warrior, AL
That or just rev match, take that synchronizers!
post Jul 16, 2014 - 10:57 PM
ricochet1490
Joined May 3, '11
From Ohio
a bunch of transmssions use full synchromesh. don't be scared of it as your only fluid. This the only thing in the nv3500 found in every manual s-10 dakota, silvarade and ram from the mid 90's through the mid 00's
post Jul 17, 2014 - 12:17 AM
Box
Joined Feb 23, '12
From Warrior, AL
Those transmissions were also designed to run on Synchromesh, where as these were not. It's like saying, "Well a lot of Borg Warner transmissions in Fords used ATF, so I guess that's just dandy in anything else I deem fit." A lot of older Honda transmissions used straight up 5W-30 motor oil. What works for one doesn't work for all.
This post has been edited by Box: Jul 17, 2014 - 12:22 AM
post Jul 17, 2014 - 7:55 AM
TClifton91
Joined May 13, '14
From Savannah, GA
QUOTE (VavAlephVav @ Jul 16, 2014 - 10:18 PM) *
I tried this little trick, no grinding at all! I would have a little harder time rev matching seeing as how my tach is broken...both of them rolleyes.gif I think I'm going to try a nice blend of oils this weekend, partly synchromesh.
Thanks guys!
post Jul 17, 2014 - 8:29 AM
QUOTE (Box @ Jul 17, 2014 - 1:17 AM) *
I've had SynchroMesh only for a year without issue.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Jul 17, 2014 - 8:51 AM
Tort1llaboy
Joined Nov 25, '13
From Norway
isent the synchronesh a temp sulution?
post Jul 17, 2014 - 9:18 AM
TClifton91
Joined May 13, '14
From Savannah, GA
Ok so I got eyes on the drain and fill plug, I see what you mean about not being able to just pour the bottle in. At my work I found a gear lube pump for marine applications, wouldn't that kind of pump work just the same?
post Jul 17, 2014 - 9:23 AM
KAOS
Joined Apr 18, '06
I just used a long stemmed, flexible funnel to sit in the fill hole. Works great.
post Jul 17, 2014 - 9:37 AM
TClifton91
Joined May 13, '14
From Savannah, GA
QUOTE (KAOS @ Jul 17, 2014 - 9:23 AM) *
Oh ok. So did you jack the car up or just feed the tube through the bay. I have gen 4 3sgte so my engine bay is unbelievably cluttered.
post Jul 17, 2014 - 10:02 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
Any oil pump will do it, they sell cheap ones at the auto parts store for $10. I had it jacked up and then measured the 2.7 qts in since its not level.
post Jul 17, 2014 - 11:54 AM
Special_Edy
Joined Oct 29, '11
The trick to rpm matching is to force pop the shifter into neutral and then apply force to shift it into the next gear. Let off the throttle and allow the rpms to slowly drop. As soon as the rpm of the motor hits the speed of that gear, it will kick into the gear, without the clutch. Due to the shape of the gear teeth, it only works if the motor is loosing rpm, so if you downshift you have to first rev the engine in neutral and then apply shifter pressure as the rpms fall (since you are shifting to a lower gear with higher rpm).
Probably best to practice with 3rd to 4th or 4th to 5th until you get smooth at it, they are more forgiving than 3rd or 2nd. Like I said slowly drop the rpms, you dont want to totally lift your foot of the throttle.
Even if you are using the clutch you should still develop a feeling for the rpm matching. With the clutch I just know how LONG to lift my foot off the throttle and when to release the clutch pedal to hit the rpms perfectly.
I probably do half my shifts in the car without the clutch and 100% of my shifting on my motorcycle without the clutch, its much smoother.
This post has been edited by Special_Edy: Jul 17, 2014 - 11:56 AM
post Jul 17, 2014 - 12:52 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (SwissFerdi @ Jul 17, 2014 - 8:29 AM) *
There have been DSM's use straight Synchromesh and their transmissions turn into slurry. Then again you're talking cheap gearboxes anyway, so if you're in that desperate of a situation to remedy it then I guess anything is worth a shot.
QUOTE (Special_Edy @ Jul 17, 2014 - 11:54 AM) *
Floating the gears really comes in handy with left foot braking, which is your BFF in a FWD car.
post Jul 17, 2014 - 1:33 PM
Special_Edy
Joined Oct 29, '11
You could try double clutching on top of rpm matching too. This would totally negate the need for synchronizers.
post Jul 17, 2014 - 2:23 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just float them, screw double clutching through eighteen gears. tongue.gif Or five in this instance anyway.
post Jul 17, 2014 - 3:30 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
And yet when I called Toyota to ask what was the recommended fluid for the transmission, expecting them to have their own special stuff, I didn't get any better of an answer he said "uh... 80/90 I think"
I had thought they would have a specific recommendation but they didn't. Other info I've seen says that the new gl-5 oil is too slippery for the synchronizers to grip right, and you should always used the gl-4 in a manual.
post Jul 17, 2014 - 3:37 PM
Box
Joined Feb 23, '12
From Warrior, AL
The thing with GL-5 is that it's corrosive to the brass synchronizers used in a lot of transmissions, GL-4 is yellow metal safe. Has to do with the added sulphur from the pressure additives. Transmissions with carbon synchronizers use GL-5.
This post has been edited by Box: Jul 17, 2014 - 3:37 PM
post Jan 27, 2015 - 7:56 PM
TClifton91
Joined May 13, '14
From Savannah, GA
Finally got around to changing my transmission oil, I used full synchromesh as recommended by prime performance. WOW! What an improvement over that black sludge I drained out. No more grinding in third, or any gear for that matter it's so smooth now. Amazing how something as simple as changing trans oil can make such a big difference. And perfect timing too, have a new 7gc short shifter on the way in the mail right now biggrin.gif. I hope it's as good as what I've read, I set my expectations pretty high tongue.gif
post Jan 27, 2015 - 11:54 PM
Box
Joined Feb 23, '12
From Warrior, AL
For the $20 or so I spent on mine it was worthwhile. Just play with it for a minute once done to reacquaint yourself and you should be good to go.
Lo-Fi Version Time is now: June 12th, 2026 - 5:57 AM
