> Strange problem to have, Gear shift lever leans to the right
post Jul 16, 2014 - 5:56 PM
toyota123
Joined Jan 13, '12
From Georgia
Finished swapping the motors yesterday started on first try and the OBD2 is working.
Only have one issue. My shift lever leans to the right. I can grab the cable from inside the engine bay and pull it towards the drivers side fender well and the lever straightens out and looks correct. As soon as I let go is falls back over. I'm hoping this is a simple fix and I'm just missing something small. Has anyway this happen before?
Thanks in advance
This post has been edited by toyota123: Jul 16, 2014 - 8:27 PM
97 Celica GT liftback DD/ project
96 corolla back up DD
Replies (1 - 9)
post Jul 16, 2014 - 9:06 PM
Does it shift properly?
post Jul 16, 2014 - 10:41 PM
toyota123
Joined Jan 13, '12
From Georgia
It does. I drove about 2 miles last night and it drives better than it did in the 97 body it was in before
post Jul 17, 2014 - 11:58 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Shift cable is the wrong length. Or more specifically the length of the cable vs the length of the housing.
post Jul 17, 2014 - 7:33 PM
toyota123
Joined Jan 13, '12
From Georgia
K I think it is short then is there a know length difference in pre face vs post face?
Motor and Trans came from a 97 GT and went into a 95GT
post Jul 17, 2014 - 9:11 PM
Special_Edy
Joined Oct 29, '11
Are you sure the cable housings are properly inserted at both ends? Did you reinstall the U shaped clips? That would be the first thing I would check...
post Jul 17, 2014 - 9:21 PM
toyota123
Joined Jan 13, '12
From Georgia
I haven't received checked the inside yet my time off is over as of yesterday and I didn'tfeel like rripping the interior apart again if I didn't have to. It was dark and raining when I put the hood back on so either way I was done for the night. I was just happy that I was able to get the obd2 working right on the first try and that it drove. It acts like the cable is too short so I guess I'll un hook it from both ends and straighten it back out and see if that works. If not I'll use the cable from the donor and let you guys know how it goes.
Thanks for all the help so far
This post has been edited by toyota123: Jul 17, 2014 - 9:23 PM
post Jul 18, 2014 - 1:29 AM
Rusty
Joined Nov 5, '07
From New Zealand
Not a quick shifter unit?
post Jul 18, 2014 - 7:02 AM
toyota123
Joined Jan 13, '12
From Georgia
I don't know for sure, haven't measured. Looks to be stock. Sits pretty high.
post Jul 18, 2014 - 5:16 PM
Rusty
Joined Nov 5, '07
From New Zealand
TRD Quickshifter isn't any shorter, it changes the pivot point. longer underneath meaning shorter throw. A short height shifter is actually worse as there is more distance your hand has to move from the wheel to the knob.
Just remove the trim around the shifter and you should be able to see if there are any spacers underneath the base of the shifter unit.
Lo-Fi Version Time is now: August 25th, 2026 - 12:42 AM
