> Vacuum lines, boost gauge, controller and DV on the same line
post Sep 2, 2014 - 2:50 PM
skogs
Joined Apr 19, '08
From Norway
I currently have two seperate vacuum lines running from the engine bay and to a boost gauge and a boost controller inside the car. They are connected via two T-pieces spliced into the dump valve vacuum line. Could this cause a problem? The HKS barely makes a sound, instead there is a faint flutter-sound, too much stuff in the vacuum line maybe?
source
T-- 100 cm-- boost gauge
5 cm
T-- 100 cm-- boost controller
10 cm
HKS ssqv
This post has been edited by skogs: Sep 2, 2014 - 2:53 PM
Replies (1 - 3)
post Sep 3, 2014 - 1:26 AM
i would have all those on dedicated lines. When you T into the boost controller and BOV bad things might happen.
post Sep 3, 2014 - 2:42 AM
skogs
Joined Apr 19, '08
From Norway
I think i will remove the boost gauge since the controller has a display anyway, so that will eliminate one. Where can i put the controllers line then?
post Sep 3, 2014 - 5:47 AM
skogs
Joined Apr 19, '08
From Norway
Can i use this as the source for the boost controller (where the blank hose is connected)? I connected it to the boost gauge, and its responding faster than when it was connected to the dump valve. Do i need a filter?
This post has been edited by skogs: Sep 3, 2014 - 9:33 AM
Lo-Fi Version Time is now: August 11th, 2026 - 8:43 PM
