> One Touch Windows
post Oct 30, 2014 - 10:07 AM
yellowchinaman
Joined Aug 11, '08
From London
So how does it know when to stop on a one touch?
A minor fault on my GT4 that the drivers side doesn't go all the way up at one click but always stop at a random point then I have to press it again to go all the way up.
At first I thought it was my switch but that's all cleaned out and checked and is ok.
What could the cause be and how do I resolve it?
Replies (1 - 6)
post Nov 5, 2014 - 6:10 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
QUOTE (yellowchinaman @ Oct 30, 2014 - 10:07 AM) *
I pulled mine apart to have a look at it and it is all done with tiny electronics... My only recommendation would be to try with somebody elses switch because I think replacement to be by far the easiest solution.
post Nov 7, 2014 - 1:59 PM
yellowchinaman
Joined Aug 11, '08
From London
Thanks. I've tried swapping out the switches several times but no difference.
Hence why I'm thinking it's something in the rails or motor mechanism.
post Nov 8, 2014 - 2:32 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (yellowchinaman @ Nov 7, 2014 - 2:59 PM) *
It's most likely the motor dying out. But you can try cleaning the rails or adding lubricant or something to it to make it glide better.
post Nov 9, 2014 - 9:51 AM
yellowchinaman
Joined Aug 11, '08
From London
So how does the window know when to stop or know when it's hit to top or bottom?
There must be some kind of sensor or micro switch somewhere?
post Nov 9, 2014 - 11:14 AM
JoshuaM
Joined Mar 6, '12
QUOTE (yellowchinaman @ Nov 9, 2014 - 10:51 AM) *
Perhaps there is a safety sensor in there that stops the window if head / arm stuck in closing window, then extra friction could falsely trigger it?
post Nov 9, 2014 - 11:42 AM
The_enD
Joined Apr 12, '13
As far as I am informed it is something like a load resistor, when the window hits the bottom or top position the motor is forced to move it even further thus causing it to use more that it's regular amperage. When that happens the circuit closes and power is cut.
Lo-Fi Version Time is now: August 22nd, 2026 - 11:06 AM
