> FS: Swapped 1995 Toyota gt
post Dec 15, 2014 - 6:28 PM
talen
Joined Dec 19, '05
From utah
So the time has come unfortunately i just don't have the time for her anymore. swapped 3rd gen 3sgte runs awesome! only 35,000 miles on motor or less. 190,000 on body it has been in a wreck before. greddy trust front mount inter cooler with custom pipping with ssq hks bov. timing belt changed distributor plugs and wires water pump when swap was done. 3inch berk down pipe with 3inch custom exhaust with high performance cat with magnaflow muffler. front struts have been replaced. slotted and drilled rotors front and rear. digital aem air/fuel ratio and dragon oil pressure gauge and boost gauge. electronic boost controller tuned gains. the out put shaft on the transmission splines are gone and so are the splines on 6puck clutch master clutch as it sits right now. so only thing it needs is new clutch and output shaft witch i will maybe be replacing here next week if no one is interested in it like that then ill get it back up and driving. comes with gt4 front clip i had shipped from japan old 5sfe motor and gt 4 transmission top mount inter cooler if you want it also if not it will be getting scrapped. I am probably missing a bunch of other stuff if interested contact me and i can give more info.
I would like 2,500 the way it sits now if i get it back up and driving i would like 3,500 obo. pictures are just before swap i will get some updated ones soon.
Thanks
http://s1186.photobucket.com/user/talen3/m...29.jpg.html?o=1
http://s1186.photobucket.com/user/talen3/m...sort=3&o=27
http://s1186.photobucket.com/user/talen3/m...sort=3&o=40
http://s1186.photobucket.com/user/talen3/m...sort=3&o=50
http://s1186.photobucket.com/user/talen3/m...sort=3&o=43
http://www.6gc.net/celicas/95-gt-4964
This post has been edited by talen: Dec 15, 2014 - 6:31 PM
Replies (1 - 1)
post Dec 18, 2014 - 5:42 PM
Celicia
Joined Dec 12, '08
From Washington DC
pm'd
Lo-Fi Version Time is now: July 6th, 2026 - 2:02 AM
