> Turbo or 4agze, suggestions?
post Feb 12, 2004 - 6:23 PM
hyp3rk1d
Joined Sep 22, '03
Ok... having a lot of trouble deciding this... i Def want to do one of these, just odnt know which 1 is the best to do.. my car has 86,000 miles on it and its an auto... iam a junior and school and dont make that much money soo iam limited a bit.. but i really want to do this... ne suggestions or comments would be appreciated...
Replies (1 - 15)
post Feb 14, 2004 - 11:03 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
how much down time can you afford?
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Feb 14, 2004 - 12:17 PM
BigEdge169
Joined Nov 18, '02
From Texas
There's a very good chance that if money is tight, you're probably much better off going with the turbo and not the swap. This is especially true since the 4agze swap hasn't even been sucessfully complete (to my knowledge) and if it has, its not a widely done swap. Also, there are plenty of people on here that have turbo'd the 7afe and would be more than willing to help you out if you have any problems. With that said, my vote goes toward the turbo.
post Feb 14, 2004 - 12:36 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
the 4agze swap hasnt been completed in a 6gc too many times, maybe once or twice that anybody here can prove.
but it does work, i have seen it done in an old tercel.
but expect a lot of down time, and a lot of little problems with a swap, especially since you have to convert to 5spd as well, which will require more parts sourcing and more money.
if money is tight, take some time to think about exactly what you want to do.
i saved money and did research for 11 months before i started putting together my turbo kit.
post Feb 14, 2004 - 11:58 PM
hyp3rk1d
Joined Sep 22, '03
still unsure but i def will think about it, thanks guys
post Feb 16, 2004 - 2:34 PM
MoralWarfare
Joined Feb 12, '04
From Hellburbia
I'd suggest fixing everything that's wrong with your car first, and then working your way up to turbo-ing the 7afe. I personally know a few people from celica.net that can help you piece together a turbo, and I'm sure there are many folks on here than can help you out too.
This post has been edited by MoralWarfare: Feb 16, 2004 - 2:35 PM
post Feb 16, 2004 - 5:49 PM
hyp3rk1d
Joined Sep 22, '03
but the engine already has 87,000 on it.. i know its not a lot, but is it even worth the time and money to turbo it??
post Feb 16, 2004 - 11:40 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
gze swaps are done in corolla's all the time
if you want to turbo, i say get the 4a-gze which is built for boost..... then later when you want the turbo, strip the s/c and take advantage of the stonger bottom end....
post Feb 16, 2004 - 11:43 PM
FallenHero
Joined Dec 26, '02
From Alabama
I asked a similar question to the crowd on club4ag, and they told me not to waist my time on an A series engine, and to get a 3sgte.
In other words, keep saving your money, and do it right the first time.
Jon
post Feb 16, 2004 - 11:59 PM
DustyBurns30
Joined Jul 31, '03
From Panama City Beach, FL
since money is tight for you, i would turbo the 7a. you can start out with little things to prepare for it and have fun in the process instead of spending all that time just saving money.
post Feb 17, 2004 - 2:27 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
QUOTE (FallenHero @ Feb 17, 2004 - 4:43 AM)
Jon
asking a question on club4ag can either get you great or horrible answers.... generally topics are pushed back so far so quickly only a few people see them and it becomes their word.....
i generally only go there for the buy/sell section......
a 4a-gze is a well built motor....
and A series motors (4a-ge) is that toyota uses in their atlantic series cars... which rev past 11,000 rpm's and put out over 240hp and are still n/a.....
post Feb 17, 2004 - 2:43 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (toyotaspeed_90 @ Feb 17, 2004 - 7:27 AM)
I'll second that...
The A series is a great seires, IMO, much more fun than the S seires. The 4AG heads are built to rev far beyond the stock specs, probably good for 9000 rpms or so, or until you start gettin valve float. The GZE blocks are very tough also, and they respond very well to boost. They can make as much power as a 7AFTE @ 12 psi which is around 190-200whp and can probably do it more reliably... but the do make a bit less torque. Power-wise, I'd take a 4AGZE over a 7AFTE basically because you're looking at essentially the same power (depending on which 4AGZE you get). The 4AGZE will be more difficult, but price-wise, they should each break even with the other. An OD pulley on the MAP 4AGZEs have shown around 190-200 to the wheels around 10-12 psi... so they can take it reliably. A turbo 4AG built off of the GZE block will be even better than a 7AFTE... but it's your call. Honestly speaking, if you're still in school and money is an issue... you should worry about school and making more money before you worry about going fast. School will help you make money, which will eventually help you reach your power goals, which will drain your money, which will........ on and on... ;]
post Feb 17, 2004 - 12:59 PM
MoralWarfare
Joined Feb 12, '04
From Hellburbia
QUOTE (FallenHero @ Feb 16, 2004 - 11:43 PM)
Jon
sorry to say this, but they're not that smart to say you should save for a 3sgte, when you have an ST and the tranny of your car will not mate up to the 3sgte.
Guys, can you still drop in a 4age or 4agze into the 6th gen STs? I know they mate very well with the 5th gen STs cos they have the 4afe in it, but does the 4ag(z)e work well where the 7afe was?
post Feb 17, 2004 - 1:55 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
all A series motors use the same mounts.... so yes.... you could do any of the following into a car that came with an A series motor:
4a-c, 4a-f, 4a-fe, 7a-fe, 4a-ge bluetop, 4a-ge redtop, 20V 4a-ge silvertop, 20V 4a-ge blacktop, 4a-gze bluetop, 4a-gze redtop
post Feb 17, 2004 - 2:32 PM
Benevolence
Joined Oct 9, '02
From San Diego, CA
I say don't do either, they both seem very uneconomical.... well atleast more than usual for you in this point in time.
post Feb 17, 2004 - 9:21 PM
FallenHero
Joined Dec 26, '02
From Alabama
just get a 20v blacktop and be done with it.
Lo-Fi Version Time is now: September 14th, 2026 - 10:06 AM
