> Fuel gauge
post Feb 19, 2015 - 1:56 AM
Marsstar505
Joined Oct 27, '14
From Rio rancho, nm
My fuel gauge has been not working lately. When I fill up the gauge only goes to about 7/8th full and will sit there for about 150 miles then drop fast. The fuel light came on today with the gauge at 1/4 and at 310 miles. Is it the gauge or the sending unit? And how do you check?
Replies (1 - 3)
post Feb 19, 2015 - 7:10 PM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (Marsstar505 @ Feb 19, 2015 - 1:56 AM) *
The issue is most likely your fuel level float in the gas tank, they can start sticking and not read correctly. I had a car that would show a 1/2 tank when it was full and turn on the gas light at 1/4 tank, thats when I was going purely by mileage to tell how full the tank was.
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Feb 20, 2015 - 6:27 AM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
Its your sending unit. it loses connection on the center pins due to being used a lot and the metal traces on the inside break the connection, then reconnects at a lower, less used area.
I just helped a friend with that issue on his ride. Yours sounds like upscaled symptoms he was having
post Feb 21, 2015 - 12:35 AM
Marsstar505
Joined Oct 27, '14
From Rio rancho, nm
What's the easiest way to test it to make sure it's that before I blow a lot of money on it?
Lo-Fi Version Time is now: August 24th, 2026 - 11:23 PM
