> strut going thru mount
post Mar 4, 2015 - 5:44 PM
Jmk91
Joined Jan 25, '15
From United States
So I installed all new KYB g2 struts with KYB mounts and brand new bump stops and sway bar end links and TRD springs. Everything is 100% new and correct parts. What's happening is the rear strut is moving like pushing threw the mount over any bumps causing a clunk sound. The nut in the rear that's in the middle of strut mount has play over any and all bumps. Like my strut isn't done correctly. The strut assembly is moving. I've replaced everything I can think of I also installed everything correctly... Ive had out the rear struts 3 times. Everything is done right I even have everything torqued to spec. So I'm lost... I didn't get an alignment yet but I honestly font want to drive my car way it is to a shop. I don't want to damage anything. Any ideas before I take it to a shop and pay out 3 arms and 2 legs. Any suggestions or ideas or if anyone else has went thru this help is greatly appreciated. Its also only in the rear. Front are fine I did all 4 at once.
Replies (1 - 26)
post Mar 4, 2015 - 6:22 PM
Box
Joined Feb 23, '12
From Warrior, AL
That is weird, unless the rear struts are defective. RocketScott on here currently had an issue with one of the front struts giving out like that and punching a dome into his hood.
2001 Miata LS 5-speed
post Mar 4, 2015 - 6:28 PM
Jmk91
Joined Jan 25, '15
From United States
It is weird. I'm clueless. They are 100% new so I'm lost.
post Mar 4, 2015 - 7:37 PM
Jmk91
Joined Jan 25, '15
From United States
I also changed rim size too If that matters. Went from OEM 15s to ENKEI ev5 17s
post Mar 4, 2015 - 8:45 PM
Box
Joined Feb 23, '12
From Warrior, AL
That wouldn't have anything to do with with it.
post Mar 5, 2015 - 2:20 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
ya those springs don't drop that low anyway. best to take it to a professional. perhaps you didn't tighten the top nut on the top mount hard enough, causing it to pop through.
post Mar 5, 2015 - 2:53 PM
Jmk91
Joined Jan 25, '15
From United States
I tightened the bolt to spec. After I did that and heard the noise I went hulk Hogan on it.. Its tight trust me lol.
post Mar 5, 2015 - 3:09 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Are you sure you lined the top cap up properly with the strut top piston? It should slide down about an inch on the piston.
The strut will depress if not lined up, allowing you to still tighten it down without noticing it is out of line.
I've done this once, and it made a lot of noise.
post Mar 5, 2015 - 5:08 PM
Jmk91
Joined Jan 25, '15
From United States
Yeah everything is lined up. New mount and strut has a flat spot so you must line it up. If not you couldn't get mount onto strut.
post Mar 6, 2015 - 12:21 AM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
Did you put the spacer back in?
I'll try to find a picture.
post Mar 6, 2015 - 12:34 AM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
It's the 90387-15012
post Mar 6, 2015 - 9:12 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
What about the little spacer washer that goes under the top nut? did you leave that out? 90387 on diagram
Bust a Deal; Face the Wheel.
post Mar 6, 2015 - 9:04 PM
Jmk91
Joined Jan 25, '15
From United States
I have the sports suspension package if that makes a difference. I don't think I had that part to begin with honestly. I took off everything and reinstalled everything part by part. All I had was strut nut followed by strut mount, bump stop and dust cover than spring. I didn't have any spacer nut/washer. My old struts didn't make any noise. My front where bad so I just replaced all 4 and did new mounts and TRD springs.
post Mar 6, 2015 - 9:09 PM
Jmk91
Joined Jan 25, '15
From United States
Wait. Son of a .... I threw that away... Well looks like I figured out the issue haha. Thank you guys.
post Mar 6, 2015 - 9:45 PM
rave2n
Joined May 29, '09
Damn.
Done my rears 3 times now, and never really noticed that spacer. I assume I've always put it back, cause it always been good in the rear.
let us know how it goes when you get it situated, now I'm curious.
post Mar 6, 2015 - 10:07 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (rave2n @ Mar 6, 2015 - 8:45 PM) *
Damn.
Oooh sleep deprivation, you never cease to entertain me.
post Mar 6, 2015 - 11:00 PM
Jmk91
Joined Jan 25, '15
From United States
Haha. Well I'll hopefully do it this weekend. I realized why I threw it away I figured my new mounts would have them... Well I was wrong haha. The new front mounts came with bearing tho. Haha thanks again and I'll let you know.
post Mar 6, 2015 - 11:50 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
I think I have a spare set of those if you need them. IIRC they were cheap and I just ordered another pair when I ordered all the other parts from Toyota.
post Mar 6, 2015 - 11:57 PM
Jmk91
Joined Jan 25, '15
From United States
QUOTE (RocketScott @ Mar 6, 2015 - 11:50 PM) *
Yeah I don't know where I put mine or if you could give me the measurements I can grab basically the same thing at Lowes. I'm just not sure how wide it is.
post Mar 7, 2015 - 2:38 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
yep, just did mine a couple of weeks ago but had an experienced friend there to help me. The new kit won't come with the spacer and you need to reuse them.
One of my rear top nuts was so rusted we had to cut it off yet not get deep enough into it to ruin the spacer.
post Mar 7, 2015 - 10:00 AM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE (Jmk91 @ Mar 6, 2015 - 8:57 PM) *
Pm me your address and I'll send them over. I'm not going to my shop today so ithey probably won't get sent till Monday.
post Mar 8, 2015 - 10:33 PM
Jmk91
Joined Jan 25, '15
From United States
free image host
Thanks you everyone. Its all fixed now. Found that spacer... Took me a few hours. But she's up and going and handles better than ever.
post Mar 9, 2015 - 2:05 PM
Box
Joined Feb 23, '12
From Warrior, AL
Huzzah!
post Mar 13, 2015 - 3:57 AM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (Jmk91 @ Mar 6, 2015 - 11:57 PM) *
I didnt measure the diameter since i figured you'd get one the size of the bolt lol But the thickness is about 1 cm for anyone else who happens to throw it away and stumbles upon this thread.
This post has been edited by Noahwhite2014: Mar 13, 2015 - 3:58 AM
post Jan 14, 2016 - 11:15 AM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE (Jmk91 @ Mar 8, 2015 - 10:33 PM) *
free image host
This thread might my savior. Been suffering with the same symptoms Jmk91 had.... rattling/clunking coming from the top of the rear struts. I had put in after market struts.
Jmk91 (or anyone who knows): Do I have to take the strut/spring completely apart or does the spacer just go in between the top of the strut and mount (i.e. unbolt the strut, put spacer on, bolt strut back up)?
Also where's the best place to buy this part... Toyota? I did find the part listed in ToyotaOverstock but seems to be NLA. What is the difference between the two part numbers listed (90387-15012) and (90387-15027)?
And just so I'm sure... one (1) spacer for each side or two (2)? The below diagram seems to indicate two "(2)".
ToyotaOverstock
post Jan 14, 2016 - 1:56 PM
Jmk91
Joined Jan 25, '15
From United States
The spacer goes on the top of the upper strut mount sir. You can actually take off the bolt with your car on the ground if you used lowering springs and add the spacer and torque nut and your done. I never tried it still on car with normal springs just lowering springs. I had trd springs.
You can actually just go down to any part store and find a spacer. I found my oem ones I threw away. Lucky me. I think they where 3/4th of an inch in height. All you need is to get the right diameter spacer. Or call dealership and get order one. If you need any help just shoot me a text 740-538-4169
This post has been edited by Jmk91: Jan 14, 2016 - 1:57 PM
post Jan 14, 2016 - 2:21 PM
Jmk91
Joined Jan 25, '15
From United States
Also its one spacer per side. The part number probably changed from year to year but any will work fine. As long as you have the same size on both sides you'll be fine. Running 3/4th inch high spacer on each side vs running 1 inch on one side 1/2 inch on other. They might have been 5/8ths but I'd go 3/4th. You'll have enough to thread the bolt on. I wouldn't go higher than 3/4th tho.
Lo-Fi Version Time is now: September 1st, 2026 - 6:01 AM
