> S54 Bearing Part Number
post Mar 12, 2015 - 9:03 AM
rave2n
Joined May 29, '09
From Gainesville, FL
Hello All!
I've dropped my S54 off at a local shop, but they are having some trouble locating the bearings I need replaced.
They've ordered a set, but what has arrived certainly doesn't seem like the right bearing. He says they are about a the size of a quarter dollar, which I've went and done the same thing and ordered the wrong ones.
So he and I humbly request if anyone knows the part numbers to the S54s Axle Shaft Bearing or another reference name is Output Shaft bearing?
Much thanks!
Edit:
I have this so far, but I'm not sure which one he requires...
90365-30017 - $61.02 - Bearing, input shaft front
90363-29006 - $32.41 - Bearing, input shaft rear
90365-32013 - $90.87 - Bearing, output shaft front
90363-25056 - $28.28 - Bearing, output shaft rear
This post has been edited by rave2n: Mar 12, 2015 - 9:25 AM
Replies (1 - 5)
post Mar 12, 2015 - 9:59 AM
enderswift
Joined Jul 12, '08
I'll dig up my old parts list and send it your way. It should have every bearing listed
post Mar 12, 2015 - 2:19 PM
rave2n
Joined May 29, '09
QUOTE (enderswift @ Mar 12, 2015 - 10:59 AM) *
You the man, I appreciate it!
I did goto your thread and saw the picture of the rebuild kit, but couldn't verify them =/
post Mar 12, 2015 - 8:35 PM
enderswift
Joined Jul 12, '08
Transaxle gasket kit: 04331-32011
BEARING (FOR INPUT SHAFT FRONT) 90365-30017
BEARING, RADIAL BALL (FOR INPUT SHAFT REAR) 90363-29006
BEARING (FOR OUTPUT SHAFT REAR) 90363-25056
BEARING (FOR OUTPUT SHAFT FRONT) 90365-32013
BEARING, TAPERED ROLLER (FOR FR DIFFERENTIAL CASE FRONT) 90366-40016
BEARING, TAPERED ROLLER (FOR FR DIFFERENTIAL CASE REAR) 90366-40064
SHIM (FOR FRONT DIFFERENTIAL CASE REAR) 90564-45001-19
SHIM (FOR FRONT DIFFERENTIAL CASE FRONT) 90564-45011
Based on your description above I'm assuming you are referring to the input/output shaft front bearings (90365-30017, 90365-32013 respectively). These are more or less the size of a silver dollar.
There is no such thing as an axle shaft bearing. Instead there are differential case bearings (which the axle stubs slide into).
Hope this helps,
This post has been edited by enderswift: Mar 12, 2015 - 8:41 PM
post Mar 12, 2015 - 8:42 PM
enderswift
Joined Jul 12, '08
oh yea, why cant they just cross reference the oem part numbers stamped on the outer race of those bearings?????
post Mar 16, 2015 - 9:48 AM
rave2n
Joined May 29, '09
QUOTE (enderswift @ Mar 12, 2015 - 9:42 PM) *
Appreciate all that info, just going to point him directly to the thread.
Can't cross reference because he hasn't opened the case, said he wanted to gather all the requested parts first. I'm in no serious rush so its not a bother yet.
Lo-Fi Version Time is now: September 15th, 2026 - 7:38 AM
