Apr 8, 2015 - 10:22 PM
Enthusiast ![]() ![]() ![]() Joined Jan 25, '15 From United States Currently Offline Reputation: 4 (100%) |
Going to be using a non air bag steering wheel but I do not want my SRS light on in my dash if it will even come on. I'd think it would.
Apr 8, 2015 - 10:40 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 23, '12 From Warrior, AL Currently Offline Reputation: 0 (0%) |
Remove the bulb.
Apr 9, 2015 - 12:19 AM
Hahaha I feel stupid now.
Apr 9, 2015 - 2:43 AM
Remove the lower center console, part with the ash tray / cup holders. The airbag ecu is under there, just unplug it and put everything back together.
Apr 28, 2015 - 10:40 AM
Enthusiast ![]() Joined Aug 4, '11 From Texarkana Texas Currently Offline Reputation: 0 (0%) |
mkernz22 will the light stay off even with the steering wheel air bag missing? I would still like my passenger side air bag to work if at all possible. I was going to try and figure out which resistor I need to trick the computer.
Apr 28, 2015 - 9:12 PM
mkernz22 will the light stay off even with the steering wheel air bag missing? I would still like my passenger side air bag to work if at all possible. I was going to try and figure out which resistor I need to trick the computer. Dont do it. Not with airbags. You can make one explode and injure someone. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Apr 30, 2015 - 10:00 AM
I've seen some kits for other vehicles that come with a plug that turns the light off.
This post has been edited by TRDweaponX: May 2, 2015 - 8:56 AM |
May 8, 2015 - 7:43 AM
Enthusiast ![]() ![]() Joined Apr 22, '07 From Buckinghamshire, UK Currently Offline Reputation: 2 (100%) |
DO not unplug anything from anywhere.
Y ou only need to unplug the driver's airbag and connect a 3.3 Ohm resistor across the 2 terminals in the loom. http://www.ebay.co.uk/itm/TOYOTA-3-3-OHMS-...=item3ce492d390 Hope this helps, J |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 7:20 AM |
