Apr 11, 2015 - 3:37 PM
Enthusiast ![]() Joined Sep 16, '13 From Grand Rapids, MI USA Currently Offline Reputation: 1 (100%) |
I just installed 7gc seats. Changed out to the 6gc pan. Everything fits and looks GREAT! However the seatback is locked to one position. The lever moves a little, but the seatback does not move. I've tore it apart three times. When it is apart, the location on the frame where the seatback bolts onto does not move either, so it is not the new seatback itself. It has to be something obvious that I am missing. Any suggestions?
This post has been edited by GTMike: Apr 11, 2015 - 4:29 PM -------------------- '99 Triple Black GT Convertible
Check out the "Michigan Toyota Scion and Lexus Crew" on Facebook. |
Apr 11, 2015 - 8:59 PM
I think that I figured it out. The crossbar at the back of the seat was not lined up correctly. Spent two hours trying to get everything lined up and failed. It is a real pain in the butt. Will continue at first light tomorrow.
Apr 12, 2015 - 7:49 PM
If you go to 7gc seats, here is a tip. Go vertical.
Put the seat together with the exception of one side of the seat back. Leave it unbolted. The crossbar is a pain to line up. Tip the seat on its side (bolts down). Move the seatback to the side enough to lower the crossbar down into the hole. You can peek on the other end under the back of the seat and see where the one end will fall to. Make note of the location of the groove where the crossbar will lock into. Turn the crossbar on the other end until it lowers onto the pin and locks into position. Let gravity do the work. You may need to reach in with your pinky finger to line up the crossbar with the pin. Once it locks into place, it will be in the correct position on the other side. Lift up a bit on the unbolted end and lower onto the pin. Bolt it up. Done. I spent way too much time attempting to line it up horizontally and clumsily trying to bolt it up only to have it fall apart. This may seem vague. When you do the switch, it will make sense. Final pics later this week. A lot more comfortable and looks sportier. -------------------- '99 Triple Black GT Convertible
Apr 13, 2015 - 8:45 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
lol. i had the same problem. had to take apart the seat a few times too. First seat took more than an hour. once i figured it out, next seat took 15 minutes.
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
| Lo-Fi Version | Time is now: September 3rd, 2026 - 6:04 AM |
