> Help - Car pops out of gear
post May 23, 2016 - 6:47 AM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
I have a very limited knowledge of transmissions and was hoping someone here might be able to diagnose my problem or tell me what to check.
Lately when accelerating in 4th gear, the shifter will pop into neutral.
3rd gear has always pushed itself towards neutral while accelerating, but never actually went into neutral.
In 3rd or 4th gear i can hold pressure on the shift knob and feel it pull towards neutral when accelerating, then if i release the throttle, it goes back fully into gear.
Recent car changes:
Teaching daughter to drive a manual. there have been some rough clutch engagements lately.
I recently bottomed out on a speed hump
my front motor mount insert has deteriorated (haven't checked the rear mount, i had installed kirkasaurus mounts years ago)
Im hoping maybe i just need to adjust the slack on a cable somewhere.
Any thoughts?
This post has been edited by Stu37363: May 23, 2016 - 6:49 AM
Replies (1 - 6)
post May 23, 2016 - 1:30 PM
Box
Joined Feb 23, '12
From Warrior, AL
Does it grind when downshifting into third and/or fourth? Synchronizers could be worn and need replaced. It's possible it could be a mount or linkage issue though.
2001 Miata LS 5-speed
post May 23, 2016 - 1:43 PM
Stu37363
Joined Jun 30, '05
No grinding at all when shifting. i was just under the car a minute ago, and the rear mount insert is gone completely. the rubber looks like it may have a crack in it, but its hard to tell until i can pull it. I went ahead and ordered another set of poly inserts, and i may pick up another rear mount. Supposedly the inserts can be used regardless of the rubber condition, but im not sure i like that idea.
I am crossing my fingers that all the items i listed as possible issues worked together to destroy that rear mount, and thats all i need to fix. I will try to follow up this weekend when i have time to work on it. hopefully i get my inserts by then. Until then i will keep checking here for other responses, and just avoid using 4th gear for now.
post May 23, 2016 - 4:07 PM
Box
Joined Feb 23, '12
From Warrior, AL
Yeah that'd be best, would suck to ruin the synchro due to a mount. Somewhat related, but if you haven't changed out the shifter base bushings that's another small possibility. If you haven't you owe it to yourself since they're only like $20 or so for a set of solid bushings off eBay, and they improve the shifter feel significantly. They come in short throw shifter kits too, but if you don't want a shorter throw and height people have started selling the bushings separately.
post May 24, 2016 - 2:42 AM
MScME
Joined May 23, '16
From Sweden
So the hypothesis is that the drivetrain has dropped causing the gear linkage to pull towards neutral? Sounds like you would experience resistance at the end of the motion in the shifter when engaging 4th in that case?
Also, if the same phenomenon is present with 3rd gear it's contradictive of this as 3rd and 4th are in the same gate, that is if the gear linkage pulls towards neutral from 4th, it would pull into 3rd from neutral as well.
Synchronizers are self-locking when fully engaged and torque is applied due to the back-taper of the synchronizer teeth, so a well functioning gearbox will pull into gear upon acceleration, not out. Sounds like there might be extensive wear on the coupling disc and sleeve back-taper.
This might occur if the driver pulls the shifter out of gear without fully disengaging the clutch, grinding the two back-tapers and wearing them down, for example when pulling very rapid gearchanges during "enthusiastic" driving so to say. Or an inexperienced driver who has an off timing between clutch end gear..?
It will take abuse of this kind over a period of time though, the taper is small, typically 4°, but the teeth are hardened.
You could try parking your car facing up a small gradient with 4th gear engaged. When you have turned your Engine off, and come off the brake, your car will roll an inch or so backwards, this is the drivetrains play. Now if you've parked at too much of a gradient, gravity will pull your car further, turning the engine over, if this happens find a new hill.
While stationary, try pulling the shifter into neutral without depressing the clutch. You should experience a lot of resistance and probably not be able to pull it into neutral without force. If it comes out easily though (be prepared with the brake) the back-taper on the coupling cone and sleeve are worn and the synchronizers 3rd-4th will need replacing.
Is it just during acceleration, or during engine braking as well? If so, then the back-taper on the opposite side of the coupling teeth are worn as well, you can test this the same way but facing down instead of up the hill.
In any case, it's a matter of exchanging the synchronizers.
post May 27, 2016 - 8:41 AM
Stu37363
Joined Jun 30, '05
Well, just fixed the mounts. The rear mount was really bad. The issue remains in 4th gear. It takes it just a little longer to happen, but its still doing it. frown.gif
post Sep 4, 2016 - 2:43 PM
wingnight11
Joined Dec 19, '14
From Saginaw, Texas
Did you figure it out? I'm having the same issue
Lo-Fi Version Time is now: August 29th, 2026 - 5:25 PM
