> Computer Audio to Factory Amp
post Feb 22, 2004 - 2:02 PM
mportobello
Joined Feb 7, '04
From Calgary, Canada
How do you connect 4 channel audio from a computer to a factory amp?
The computer has 2 miniphono plugs, front and rear stereo. Using an adapter/splitter I get 4 RCA connectors:
front left
front right
back left
back right
I have got a wiring harness that I believe connects to the factory amp (American International TWH-950). It has 8 leads for:
front right positive (+), front right negative (-)
front left positive (+), front left negative (-)
back right positive (+), back right negative (-)
back left positive (+), back right negative (-)
For each RCA connector, can I connect the associated the speaker leads with:
RCA center conductor -> positive
RCA shield -> negative
Replies (1 - 6)
post Feb 23, 2004 - 3:25 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
do you not have rca input's in your amp?? other then not, its not a great idea to splice rca's an wire then up. but it will work
post Feb 23, 2004 - 9:00 PM
mportobello
Joined Feb 7, '04
I don't believe the stock amp has RCA connectors. Is that correct?
post Feb 25, 2004 - 2:02 PM
aaronc222
Joined Sep 22, '02
From Detroit
You answered your own post. Yes you can strip the RCAs and connect them to the harness. The harness should accept low-level signals, like the ones from the RCA cord.
post Feb 26, 2004 - 2:10 AM
mportobello
Joined Feb 7, '04
Is it speaker + to the RCA center post and speaker - to the RCA shield?
post Feb 26, 2004 - 4:45 AM
aaronc222
Joined Sep 22, '02
From Detroit
QUOTE (mportobello @ Feb 26, 2004 - 12:10 AM)
post Feb 26, 2004 - 2:44 PM
mportobello
Joined Feb 7, '04
Thanks, but I am not proficient with smilies. Does wink.gif mean yes, no, maybe, don't know, or I'm a Gemini what's your sign?
Lo-Fi Version Time is now: August 2nd, 2026 - 3:53 PM
