> FS: 96+ diamond clear indicators, SOLD. Mods, please close.
post May 30, 2017 - 11:53 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
$35 shipped anywhere in the continental US.
TRD rad cap was sold.
This post has been edited by HectortheRican: Aug 21, 2017 - 9:10 PM
June '12 COTM
'95 AT200
Replies (1 - 7)
post Jun 5, 2017 - 8:51 PM
HectortheRican
Joined Dec 26, '09
bump
added to original post
June '12 COTM
'95 AT200
post Jul 1, 2017 - 2:43 PM
HectortheRican
Joined Dec 26, '09
bump
June '12 COTM
'95 AT200
post Jul 4, 2017 - 8:35 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Im curious, what's the purpose of a high pressure rad cap?
My Celica!
post Jul 5, 2017 - 3:09 PM
HectortheRican
Joined Dec 26, '09
QUOTE (jordisonjr @ Jul 4, 2017 - 7:35 AM) *
It allows the engine to run a bit hotter, since it will take a higher coolant system pressure to cause a boilover into the reservoir under high loads.
Probably not too ideal for daily driving, but a good upgrade for any sort of racing - especially if you're running a higher-capacity aluminum radiator.
June '12 COTM
'95 AT200
post Jul 20, 2017 - 8:29 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
http://www.tuneruniversity.com/blog/2011/0...e-radiator-cap/
Hmm ill be buying the turn signals from you soon enough
to answer you question. you can run a 70 solution distilled water to 30 coolant ratio when on the track since water dissipates heat from engine better than coolant. a 50/50 ratio of coolant to water isn't ideal on the track. but water also freezes at 32 degrees, but running water all the time even in warm climates causes rust in engine.
This post has been edited by BonzaiCelica: Jul 22, 2017 - 9:11 PM
post Jul 30, 2017 - 4:32 PM
SoDo
Joined Dec 16, '07
From Chicago, IL
Payment sent for the trd radiator cap
1999 Celica GT Hatchback
post Aug 21, 2017 - 9:01 PM
BonzaiCelica
Joined Apr 24, '08
mods might want to close this now!!
Closed TopicStart new topic
Lo-Fi Version Time is now: August 28th, 2026 - 4:03 AM
