> Check engine code 12
post Oct 24, 2018 - 11:44 AM
Oreo20
Joined Jan 27, '14
From Houston
Need some tips/help in trouble shooting this thing
And
Finally managed to jump the system to bring the code into the dash
The check engine light comes and goes
So found the perfect time to do it.
But now what ? What is code 12 and what should I do ?
Thanks for anyone that answers
Replies (1 - 6)
post Oct 24, 2018 - 2:20 PM
Box
Joined Feb 23, '12
From Warrior, AL
Not to be rude, but this is easily found with googling "Toyota OBD1 Codes". That said I'm nice and will tell you that code 12 is for missing engine speed signal, so something is wonky with your distributor. If you take your distributor cap off it'll probably look like copper spaghetti inside, that or your ignition coil is cracked. That's provided your wires, rotor & cap, and plugs aren't needing replaced anyway. If it's not having any other issues aside from flashing the code it's probably one of the more simple ones.
This post has been edited by Box: Oct 24, 2018 - 2:39 PM
2001 Miata LS 5-speed
post Oct 25, 2018 - 7:38 AM
Oreo20
Joined Jan 27, '14
From Houston
Thank you kind sir
My dizzy was replaced maybe 2 months ago
Bought a cheap after market and forgot the gasket /:
It’s leaking oil
I will give it a check thanks. Ya the car runs fine just the light comes and goes but now it’s veing more persistent
post Oct 25, 2018 - 3:11 PM
Box
Joined Feb 23, '12
From Warrior, AL
If oil is getting into the cap that'd do it, though that's usually only if the shaft o-ring seal tears. Though the way the distributor is mounted on these, if I recall correctly, perhaps via that gasket as well. I'd definitely go in and clean everything up and put in a gasket.
post Oct 25, 2018 - 4:15 PM
bryanf
Joined Jul 26, '12
From Atlanta
Keep this in mind, too:
QUOTE (Bitter @ Oct 15, 2018 - 10:49 PM) *
The aftermarket distributors are plagued with problems when they're hot, most fail in some way or another. https://www.toyotanation.com/forum/130-coro...ult-issues.html
post Oct 26, 2018 - 11:01 PM
Yupe7
Joined Mar 4, '18
From Oregon
Box is right the problem could be with distributor housing assembly here is what you could do to check if it the distributor
This is in the distributor
Good luck
post Oct 28, 2018 - 12:51 PM
Oreo20
Joined Jan 27, '14
From Houston
It was the dizzy thanks guys for the great help
Lo-Fi Version Time is now: August 25th, 2026 - 7:21 AM
