> My first Celica - incl. project video series!
post Jul 29, 2019 - 4:32 AM
Shizukesa
Joined Jul 12, '19
From UK
Hello everyone!
I just randomly won an auction for a Celica SR on eBay and only ended up paying £350 with 12 months MOT and no advisories.
I'm coming from a 2004 Yaris 1.3 vvti so it's nice to have a little extra power and there's already an exhaust on it, man the 7afe sounds sweet!
Here she is...
https://imgur.com/oE4dJvD
https://imgur.com/wOEv7Mn
I really had to clean it up because it was pretty disgusting but worth the elbow grease. It needs a cam belt and I'm not quite sure if I should tackle it myself or not.
Happy to finally be a Celica owner! smile.gif I'll probably keep this until my next insurance change in Feb and then get a GT.
PROJECT VIDEO SERIES on my YouTube channel: https://www.youtube.com/channel/UCngPT2nnen...mZl7CJVw/videos
Paul
This post has been edited by Shizukesa: Aug 22, 2019 - 9:45 AM
Replies (1 - 16)
post Jul 29, 2019 - 2:16 PM
Box
Joined Feb 23, '12
From Warrior, AL
Welcome! Looks like a very nice car for very little money, well done! If you're good at following instructions and have some mechanic ability you should be able to do the timing yourself, aside from being transversely mounted making it harder it's a good learning opportunity since the 7A is non interference so there's not the stress of getting it wrong and trashing the engine.
2001 Miata LS 5-speed
post Jul 30, 2019 - 10:35 AM
Hood spoiler! Looks tidy for the money spent.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Jul 30, 2019 - 8:59 PM
Shizukesa
Joined Jul 12, '19
From UK
I decided to get a garage to do it after doing some research about the cam belt change.
Some more pics:
Wheels need refurbishing, front bumper needs respraying and scratches on the rear right need sorting out.
Today I had to modify a corroded exhaust bracket after I noticed the hanger wasn't even connected.
post Jul 31, 2019 - 3:05 PM
Shizukesa
Joined Jul 12, '19
From UK
Worked like a charm!
Also nice polished exhaust tip!
post Aug 10, 2019 - 5:42 PM
Shizukesa
Joined Jul 12, '19
From UK
Before:
After:
Also the throttle was sticking a little so I cleaned the throttle body today.
It's idling high after this, does anyone know the procedure for idle relearn on a Celica AT200? smile.gif
Before:
After: (this was as clean as I could possibly get it)
post Aug 11, 2019 - 2:12 PM
Box
Joined Feb 23, '12
From Warrior, AL
http://www.6gc.net/howto/reset_your_air_fuel_ratio
Though that may not help as I tried it after the following; I had the same issue after cleaning my throttle body and IACV, I could've swore it had a vacuum leak so I redid the gaskets like two or three times and on the third time I gave up. After driving it though it seemed to settle down to where it was before. Also make sure the A/C idle up circuit isn't disconnected now.
post Aug 11, 2019 - 5:08 PM
Shizukesa
Joined Jul 12, '19
From UK
QUOTE (Box @ Aug 11, 2019 - 3:12 PM) *
Ah thank you so much for your reply! I'll give it a try and if I have no luck then perhaps there's still some carbon build up around where the throttle plate is. Either that or I'll drive it for a while and see if it settles.
post Aug 22, 2019 - 9:46 AM
Shizukesa
Joined Jul 12, '19
From UK
Feel free to come along for the ride!
post Aug 22, 2019 - 9:47 AM
Shizukesa
Joined Jul 12, '19
From UK
I tried it... I actually thought it worked...but then it turned out the throttle cable was also too tight! biggrin.gif
post Aug 26, 2019 - 2:54 PM
cheela
Joined Feb 2, '07
From Berlin, WI
glad it was still an easy fix regardless. looking forward to more progress!
post Aug 26, 2019 - 7:18 PM
Box
Joined Feb 23, '12
From Warrior, AL
Woo working! Ha, throttle cable too taught is just as bad as too slack.
post Aug 28, 2019 - 4:18 PM
Shizukesa
Joined Jul 12, '19
From UK
Resprayed the heat shield today...
Before:
After:
post Aug 29, 2019 - 10:51 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Nice! I probably would have done it black, but clean is better!
~bloodMoney
post Sep 6, 2019 - 3:17 PM
Shizukesa
Joined Jul 12, '19
From UK
QUOTE (bloodMoney @ Aug 29, 2019 - 11:51 AM) *
Yeah I was thinking about doing the valve cover, heat shield and intake manifold all black... perhaps I still will.
post Sep 10, 2019 - 5:15 PM
Shizukesa
Joined Jul 12, '19
From UK
Engine when I bought it:
Engine so far:
Bumper filler (it was in a terrible state and this was my first time):
After respray but still not polished:
post Mar 20, 2020 - 5:56 AM
rensebed
Joined Mar 12, '20
From Phoenix, Arizona, USA
Any update on this project?
Lo-Fi Version Time is now: September 13th, 2026 - 5:57 AM
