May 13, 2011 - 10:14 PM
Enthusiast ![]() ![]() Joined Sep 27, '07 From Raleigh, NC Currently Offline Reputation: 0 (0%) |
Hey guys I'm looking to buy this gasket individually. Mine's bad and causing a bad leak ie needs to be replaced. Any idea where? Its the gasket @ the 4 to 2 split(2 holes). If anyone has the dimensions I might be able to have a friend machine one. Thanks guys
Hey guys I'm looking to buy this gasket individually. Mine's bad and causing a bad leak ie needs to be replaced. Any idea where? Its the gasket @ the 4 to 2 split(2 holes). If anyone has the dimensions I might be able to have a friend machine one. Thanks guys http://s847.photobucket.com/albums/ab35/j0...ent=WTBthis.jpg -------------------- |
May 14, 2011 - 10:53 PM
Enthusiast ![]() ![]() Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
You don't want to machine one. You should be able to buy generic flat gasket and cut it to fit. I have made several for other gaskets before just make sure that it can handle the heat.
| Lo-Fi Version | Time is now: June 14th, 2026 - 1:33 AM |
