Failed Smog Test - All Emissions High |
Nov 9, 2016 - 10:32 AM |
Enthusiast Joined Feb 1, '14 From Phoenix Currently Offline Reputation: 0 (0%) |
Hi. Could use some advice. 94 ST Manual rebuilt engine
Previously had CEL with code 071. Replaced ERG valve, EGR modulator, and 1 vacuum hose. CEL fixed. Went to have car smogged and all emissions are high. Here are the numbers: 15 mph HC=95 CO=0.53 NO=795 25 mph HC=82 CO=0.41 NO=763 Not sure where to begin. Should I just replace both O2 sensors to start and then retest? Any advice appreciated. Thanks! Jay |
Nov 11, 2016 - 6:44 PM |
No one has any ideas at all??
Nov 11, 2016 - 7:47 PM |
Without knowing the limits and by how much you failed it's hard to say but just check that everything is in spec like ignition timing, plug gap, coil resistance, etc.
Nov 12, 2016 - 9:47 AM |
Probably running rich.
How old is the 02 sensor ? -------------------- |
Nov 12, 2016 - 7:22 PM |
I don't know that it's ever been replaced.
Nov 14, 2016 - 4:43 PM |
your NO is really high, try using 91 gas next time. also look for vacuum leaks and exhaust leaks
Lo-Fi Version | Time is now: May 9th, 2024 - 5:25 AM |
