mattjw UK st205 project |
Feb 11, 2012 - 10:02 AM |
Enthusiast Joined Mar 4, '08 From Aldershot,Hampshire Currently Offline Reputation: 0 (0%) |
Nice car - strange being a later spec car that it has no skirts
have the holes been filled - im taking it they have been. For me a shiny black faff will always look better than a white one - just look more aggresive and menacing -------------------- Women are snakes with tits
Feb 11, 2012 - 11:44 AM |
Enthusiast Joined Feb 6, '12 From leamington spa, UK Currently Offline Reputation: 0 (0%) |
what year do the late spec st205s start? what are the differences?
Feb 11, 2012 - 2:20 PM |
'96+ are late spec. Non-GT4 models got an updated front bumper and spoiler, and all models got side skirts. Some GT4's came with the updated spoiler as well, but I don't know what percentage that was. There were also updated head and tail lights available on ST202's and ST205's.
This post has been edited by richee3: Feb 11, 2012 - 2:22 PM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Feb 11, 2012 - 3:30 PM |
As above the facelift was 96.
The chrome " celica " sill covers were a option as were recaro seats - but these were also offered for the pre face lift. then in 98 the GT4 was revised again - out went the 3 post rear spoiler and reverted to the WRC style rear wing with raiser blocks but with a different GT FOUR text on them and all got the projector headlights and silver coloured dash trim -------------------- Women are snakes with tits
Feb 26, 2012 - 2:11 PM |
fitted a sparco 350mm suede wheel love it
and gave her a wash -------------------- |
Feb 26, 2012 - 5:55 PM |
Enthusiast Joined Dec 16, '11 From The Netherlands Currently Offline Reputation: 5 (100%) |
Got a underside body pic? So i can see your exhaust system?
May 5, 2012 - 3:56 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
Any updates on this build? Your car amazes me, I'm eager to hear more about this Four ^^ Especially engine-wise
Jan 11, 2014 - 6:33 AM |
just found this old project thread and thought i would update, a lot has happened since the last post!
Things took a slight turn for the worse. Overboosting, clutch problems, seized calipers, huge rust holes in the sills and rear quarter and a fuel leak meant she was clearly begging for a little attention. So i bought a bmw e36 328 to use as a daily drift weapon and put the celica in the garage so the fun could begin. First on the purchase list was a donor quarter panel then up in the air she went, ready for some serious grinding. New discs, pads and caliper pins visible in this shot although i ended up sending all four calipers to BIGREDD for reconditioning (they did an incredible job, highly recommended) and I began gutting the interior. This is very much a before photo Then the bodywork began - I ground back the area to see how far the surface rust extended, and found some filler from a previous repair further forward but otherwise the arch profile was looking better than expected. Inner skin however was very worse for wear and then, hours of grinding, drilling, flapwheeling and welding the following occured, heres a nice condensed version of the hours that followed - tacced into place - welded and ground back - filler lashed on - arch rolled to a nice even profile with loads of clearance for the wheels given, then hours of filling and flatting - -------------------- |
Jan 11, 2014 - 6:39 AM |
a quick shot of the interior before i fitted buckets, floorpan completely stripped of sound deadening and all sprayed satin black. Also removed all the loom for the bits n pieces ive whipped out, arial and motor, rear wiper mechanism, speakers etc
and the sparcos pre-fitting - Also, removed the sunroof assembly which weighed in at 14kg, perspex replacement can be seen taped up but resting in place. nice and simple inside now also patched the lower right sill due to more rot also whipped the bumper and slam panel off the front and started stripping out the charge cooler system and aircon to make room for FMIC clocked turbo and intercooler in place then off to the paint shop she went, most of the left hand side was blown in and now puts the rest of the car to shame! -------------------- |
Jan 11, 2014 - 6:43 AM |
exedy paddle clutch and fidanza lightweight flywheel are both now fitted, along with a new cambelt kit.
The current filler neck had a hole in the back and its seized onto the tank so a new tank and filler neck are on their way which will sort the fuel leak issues -------------------- |
Jan 11, 2014 - 6:49 AM |
Enthusiast Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) |
Really nice car, dude.
Jan 11, 2014 - 2:35 PM |
Enthusiast Joined Mar 26, '12 From Hungary Currently Offline Reputation: 0 (0%) |
This is one of my favourite Celicas here! Glad to see that you not left her diying! Keep posting those nice pics!
Jan 17, 2014 - 7:58 PM |
SOOO GLAD you finally updated!
I've finally decided to respray the whole car in black and when I will come out of school and get my job, our cars will be very very similar ^^ Will need to fix the same areas on mine also due to minor, yet horrible to me, rust problems. I will get BC coilovers also, but not quite sure yet of the stiffness to opt for. Thinking to go 9kg front/8kg rear, I want to get a close rear/front stiffness ratio to make the car more prone to oversteer rather than understeer. What specs are yours? What is your feedback? Too stiff for a daily driver? Would you change to another setting if you could go back? What are your future plans? Please keep us updated Edit: Pretty sure the offset is +23 may be wrong though Also, do you run minor negative camber to make the 9.5 fit in the front? This post has been edited by dudeofchaos: Jan 18, 2014 - 8:11 PM |
Feb 23, 2014 - 12:00 PM |
Enthusiast Joined Oct 25, '11 From Tbilisi Currently Offline Reputation: 3 (100%) |
Feb 23, 2014 - 3:04 PM |
Enthusiast Joined Mar 6, '12 From Brisbane, Australia Currently Offline Reputation: 6 (100%) |
WOW! Those pics look great... and then that strip down... wow -------------------- SOLD :( 1997 ST204 Celica ZR -----> See it here on 6GC! 2013 October Celica of the Month XD Now: '00 NB8B Mazda MX5 -----> See it here in off topic! |
Aug 4, 2017 - 12:44 AM |
I know this is a case of holy **** revival but I am very curious to know what happened to this car!!
Lo-Fi Version | Time is now: May 10th, 2024 - 7:52 AM |
