500 AWD Project, Celica Project |
Apr 20, 2017 - 3:53 PM |
Enthusiast Joined May 12, '10 From dhaka Currently Offline Reputation: 0 (0%) |
Hi there guys, well like the title says, building a 3S-GTE with at least 500 at the wheel. Here in Dhaka, Bangladesh, the Evos and STIs are running wild with 450-650awhp! Just wanna give most of them a run for their money!!
Please let me know if I need to add something or if I am doing something wrong. All your inputs are appreciated and thank you in advance. It's a 5th Gen ST185 with 3rd Gen 3S-GTE (JDM Spec, 245hp). The MAF/AFM had to go!! MOD LIST 1) Full Brian Crower stroker kit, 2.2 ( 2.26L - Includes 4340 billet crank, 93mm stroke, H-beam BC625+ rods (5.433 c-to-c), and custom forged pistons (87mm, 9.0:1 CR). ACL Race bearings available separately.) 2) Brain Crower 1mm OS Valve both Intake and Exhaust 3) Brain Crower Valve Spring with Titaniun retainers, Valve Keeper, Valve Guide 4) Brain Crower Stage2 Camshafts (264 degree) both Intake and Exhaust with Fidanza Cam gears 5) Cometic Head Gasket (1.2mm) 6) Precision full turbo kit with 3" Downpipe Turbocharger: 5830 58mm Billet ~560whp Turbine Housing: .48 A/R (quicker spool) Compressor: As Cast (standard) Turbine Finish: Turbo Black Ceramic coated Wastegate Dump: Rerouted (standard) Wastegate: Silver 38mm MV-S 7) Mega Squirt PnP EMS 8) KO Racing Custom Turbo Manifold 3SGTE Gen3 9) ATS Racing Intake Manifold with 70mm Throttle Body Gen3 10) ATS Top Feed Fuel Rail Kit with 720cc injectors 11) MSD Ignition coil and KE-85 Plugwires 12) Blitz Nur Spec-R Exhaust System, straight 3" Pipe from downpipe, no cat 13) K&N Air Filter 14) Mishimoto Intercooler with 3" hard piping 15) Mishimoto Radiator with 2 Racing Fans (16" with 5 blades) 16) Mishimoto Oil Cooler 17) Mishimoto all Silicone Piping 18) Full SuperPro Polyurethane bushing (Top to bottom including engine mounts and diff mounts) 19) H&R Lowering Springs (HATE Coilovers), Koni shock absorbers 20) Whiteline strut bars (Front and rear), Ultra Racing fender bar, front and rear brace bar 21) OS Giken STR2C Clutch kit with flywheel (Torque Rating: 570 ft/lbs) but feels like stock 22) ARP Bolt for head and block 23) AEM Water/Methanol Injection Kit 24) Enkei RFP-1 Lightweight Rims (Gold color). 17x8, 5x100, 45 offset 25) 235/45/17Y Yokohama Advan Neova AD08R Tires 26) TRD Short shifter with M1 Abram Shift Knob (Black Satin with pattern) 27) GT-4 WRC Wing JDM Spec 28) Apexi AVC-R Boost Controller or Blitz SBC R 29) Depo 60mm (Boost, Oil Pressure, Oil Temp, Water Temp) 30) Innovate AFR 31) Apexi RSM 32) HKS Turbo Timer Type-O 33) MOMO MOD. 07 STEERING WHEEL with hub 34) Carbon Fiber Hood 35) EBC Brake Disc & Yellow Stuff Pads & SS Brake Lines This post has been edited by salman2510: Apr 21, 2017 - 5:28 PM |
Apr 20, 2017 - 4:06 PM |
Enthusiast Joined Dec 9, '14 From Juneau, Alaska Currently Offline Reputation: 3 (100%) |
That's an awesome list of upgrades! I'm struggling to afford to paint my Celica one color but at least it drives. Most of my extra money goes into my movie making. Be sure to post pictures of your progress!
Apr 20, 2017 - 9:54 PM |
that should do it
Apr 21, 2017 - 3:49 AM |
that should do it Thanks mate, appreciate your kind words. I was wondering if I could fit 17x9 rims as I need a lot of traction. Planning on hitting 28psi. You think 17x8 and 235 tires will do? I don't know why, but 245 makes me more confident!! Maybe it's just me. That's an awesome list of upgrades! I'm struggling to afford to paint my Celica one color but at least it drives. Most of my extra money goes into my movie making. Be sure to post pictures of your progress! Nice to know the money goes into something you like. There is no greater satisfaction! I don't know how to attach pictures. I can't find the attachment button anywhere!! |
Lo-Fi Version | Time is now: May 10th, 2024 - 7:58 PM |
