2 Pages V  < 1 2
> Clunking noise from rear?
post Mar 8, 2004 - 12:20 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Are you sure your calipers are clearing the wheels? I dont know how they couldnt because the rear calipers are pretty small but it might happen.
post Mar 10, 2004 - 11:52 PM
rsos1
Joined Nov 5, '02
From Illinois
Did anyone ever find anything out?
post Mar 11, 2004 - 7:07 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
not yet.. My rear sway bar does seem kinda loose in the bushings though. All the bolts are tight but its able to move up and down in the bushings. I dont know if it normal or not. I havent had anytime to check it out anymore. Its been to cold here!
post Mar 11, 2004 - 6:55 PM
wind
Joined Nov 4, '03
From Vancouver, Canada!
QUOTE (pdxgtcoupe @ Mar 6, 2004 - 11:35 PM)
Hopefully it is what happened to me cause it was cheap and easy. I had a BAD clunking sound and FINAlly traced it to my rear sway bar bushings. The car was up on a lift and i grabbed the sway bar and I was able to move it easily. I got the parts for i think aroung 8 bucks, and it took me 10 minutes total to swap them out. BINGO!!! I have H&r's and GR-2's, so i thought it was becaeuse of that... did the spare tire thing... the jack... strut mounts... end links and finally the sway bar bushings
Its the two rubber mountson the bar with the end links with brackets and i believe they are 12mm bolts.
are you people blind or just dumb?
read the quote....common people
post Mar 11, 2004 - 11:19 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
so you are saying that if there is some play in the rubber bushings then this is must likely it?
2 Pages V  < 1 2
Lo-Fi Version Time is now: September 14th, 2026 - 6:37 PM
