> HP???
post Mar 5, 2004 - 8:26 AM
latinomasfino
Joined Feb 17, '04
i have a 94 celica st 1.8L how much would my horsepower be if i installed iridium sprark plugs, ngk wires, cold air intake, 2.25 inch exhaust system, and replaced the catalytic converter with a st8 pipe?
Replies (1 - 13)
post Mar 5, 2004 - 8:27 AM
latinomasfino
Joined Feb 17, '04
oh yea and if i had headers do they give u any HP?
doGGy
Joined Oct 28, '02
From Europe, Lithuania
in the best way 120 hp........ maybe bit more (on the flywheel)
<<<<<< DCw / JDMart >>>>>>>
post Mar 5, 2004 - 8:29 AM
doGGy
Joined Oct 28, '02
QUOTE (latinomasfino @ Mar 5, 2004 - 6:27 AM)
H E A D E R not the headers...... (exept you are going to get separet headers for every cilinder...... biggrin.gif biggrin.gif biggrin.gif)
post Mar 5, 2004 - 11:03 AM
boosted_K2
Joined Aug 30, '02
From Michigan
you may break 100 FWHP
No but I don't buy it
Cause I'm...
post Mar 5, 2004 - 12:54 PM
SpedToe169
From Dallas, Tx
I've dynoed all this stuff except the header. Expect around 105hp and 114ft-lbs of torque if everything is tuned properly.
post Mar 6, 2004 - 2:14 AM
latinomasfino
Joined Feb 17, '04
why just 105 isnt stock 115?
post Mar 6, 2004 - 2:17 AM
boosted_K2
Joined Aug 30, '02
From Michigan
115 is BHP at the flywheel, me and john are refering to WHP, where it really matters, after the drivetrain loss.
Cause I'm...
post Mar 6, 2004 - 11:23 AM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
Just to let you know, NGK wires are the same as stock... they are just blue and made by NGK, no power gains can ve expected there.
post Mar 6, 2004 - 12:39 PM
Dont EXPECT power gains from anything you do with the distributor/plus/wires...just do it so you have a healthy car.
post Mar 6, 2004 - 1:52 PM
latinomasfino
Joined Feb 17, '04
are headers gonna give me a boost??? how much and is there anything else i can do besides the swap imj probably gonna do the swap in like 2 years or so once i start doing real estae
post Mar 6, 2004 - 7:08 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
well, a header will simply improve air flow, so it will show some hp gain.
post Mar 6, 2004 - 9:38 PM
Chrobis
Joined Apr 15, '03
yeh but a header without a front pipe, and cat back is pretty useless cause the air just gets "tied up" somewhere else.
post Mar 6, 2004 - 9:46 PM
boosted_K2
Joined Aug 30, '02
From Michigan
not necessarily. you will loose torque, but usually gain HP
front pipe?? do you mean mid-pipe??
Cause I'm...
Lo-Fi Version Time is now: August 27th, 2026 - 1:02 AM
