> internal engine parts
post Mar 6, 2004 - 11:21 AM
http://www.importperformanceparts.net/
this is the site i was looking around, and i went to toyota, then camshafts, then topline camshafts, then down to a 7afe celica, will this work?!?!? will it help me out any?
oh and also they say they have connecting rods under the connecting rods section and then in topline
This post has been edited by playr158: Mar 6, 2004 - 11:29 AM
Replies (1 - 14)
post Mar 6, 2004 - 7:16 PM
SpedToe169
From Dallas, Tx
Wow, good find. They actually have a lot of stuff for the 7a, but dissapointingly, most of it is OE replacement parts. The rods and the cams for the 7a are all stock parts.
I'm excited about their engine rebuild kits, thats going to save me a lot of time sourcing parts and buying stuff from toyota.
post Mar 6, 2004 - 10:40 PM
so where can i find forged pistons ?>
post Mar 7, 2004 - 12:23 AM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
As far as I know, you'd need to have custom forged pistons made for the vehicle. Crower, J&E, or Wiseco should be able to help you... If there is an off-the-shelf option, I hope someone informs us both.
post Mar 7, 2004 - 2:24 AM
DustyBurns30
Joined Jul 31, '03
From Panama City Beach, FL
i'm sure 90% of you know this by now, but when i talked to raeeng.com about custom forged rods to fit some 4a-gze pistons, they quoted me $700 just for the rods. i even sent them one of my old rods to see if any of there existing stock could be modified or machined to work but they had nothing. so if your looking to get a piston/rod combo, you will probably be looking at $1100 not to mention the rebuild kit and new rings/ bearings that your going to need. well worth it in the long run of forced induction but it will hurt at the time of transaction.
post Mar 7, 2004 - 12:09 PM
SpedToe169
From Dallas, Tx
Yup, $1100 sounds about right. I'm keeping the stock rods, working them over and getting pistons made. I think I'm going to have Arias make my pistons. You really shouldn't need rods unless you're running INSANE boost (~20psi) or spinning the engine faster. I'm going to have my stock rods magnafluxed, beam polished, and shot peened and they should be able to take anything I can throw at them.
post Mar 7, 2004 - 4:30 PM
DustyBurns30
Joined Jul 31, '03
how much will that cost to do all that machining on the rods? also, do you recommend performance rod/main bearings and those toga performance rings with medium boost pressures (like 8-12 psi)?
post Mar 7, 2004 - 6:27 PM
Hym3n
Joined Sep 5, '03
From Grapevine, TX
I know this has been asked before, but on that site there's a turbo kit for the 7afe 'rolla. Quite some big gains on that, and the price is pretty damn nice IMO. What changes need to be made from that one to fit on ours?
-brian
post Mar 7, 2004 - 7:19 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
i'll keep you guys posted.... the guy who helped me with my motorswap (who has a te51 that turns technical peoples heads when the hood is open, 2 ae86's, an mr2, an ae92 gts, and 2 first gen celicas) is going to be building a 7a-gze.... i'll let you guys know how he builds the bottom end... i know he'll be using mainly 4a-gze parts.... & this guy DEFINATELY knows that he's doing....
post Mar 7, 2004 - 8:11 PM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE (SpedToe169 @ Mar 7, 2004 - 10:09 AM)
Have you thought of having your rods cryogenically treated? Supposedly, it makes a HUGE difference strength wise. I read about a turbo engine: It needed a new turbo every six runs. After they treated all the turbo's parts, it made over a hundred runs with no problems.
post Mar 8, 2004 - 12:11 PM
initialdrift55
Joined Sep 23, '03
From Miami,FL
to bring it up again what types of changes will this turbo kit for the 7AFE Corolla need to fit in our st's?
post Mar 8, 2004 - 1:24 PM
DustyBurns30
Joined Jul 31, '03
i believe you will need a custom down pipe, and you may run into problems with the length on the oil lines and such. you would be better off just buy that turbo seperate (if that's the one you really want) and round up the other parts through jgstools.com, ebay, and performance import sites. that method will also save you money as well. if you look at the list of items that comes with the turbo kit, it doesn't quite come with everything you need.
can someone post a link to that page that has a basic list of items for a custom turbo setup?
thanks
post Mar 8, 2004 - 7:57 PM
SpedToe169
From Dallas, Tx
I don't know the cost, its not outrageous, call your local performance machine shop. Yes, get the better bearings and rings.
I've done a lot of research on this for other things. Its merits are quite debateable. Some people say it works, some people say it doesn't. It doesn't seem to hurt, but doesnt' always help either. It does not increase strength. That is a property of the material itself which doesn't change. Shotpeening is very similar (but also very proven) in that it helps decrease the chances of failure by reducing or nearly eliminating stress risers, stress concentrations, and surface imperfections which can lead to crack formation and premature fatigue failure.
That really sucks. Making a new downpipe is no big deal, but sourcing all the BS little parts you need is a total PITA. Thats all thats holding me up at this point. I have all the big stuff. Just trying to round up all the little BS stuff.
post Mar 10, 2004 - 7:16 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
there are "off the shelf pistons" for the 7a.. qutoed from doggy the 4agZe pistons work.. i got my set (not yet installed) from my toyota dealer.. with rings $250.... rods will we are left from custom there. and about the corolla kit, your better off building from scrach.
post Mar 10, 2004 - 9:21 PM
FallenHero
Joined Dec 26, '02
From Alabama
You need to get those pistons fitted to the rods and let us hear how it was done!!! Has doggy done it yet?
Lo-Fi Version Time is now: August 4th, 2026 - 9:15 AM
