> Speed governor in an ST, is there one? can it be removed?
post Mar 7, 2004 - 2:11 AM
belizecelica
Joined Feb 4, '04
From Tampa
Hey guys, is there a governor in the ST?? If so, where and can it be safely removed? is it legal to remove it?? Whats the top speed if it is removed??
Replies (1 - 12)
post Mar 7, 2004 - 2:54 AM
aaronc222
Joined Sep 22, '02
From Detroit
As far as I know, some have one and some don't. If it does, it tops out at 118. If not, the gears will only reach ~135(5th gear at 6200 rpm). From what I've heard, the governor came on cars with H rated tires from the factory.
post Mar 7, 2004 - 12:04 PM
SpedToe169
From Dallas, Tx
Arron is right, but they're at 111mph (on the gps, the speedo is a ways off).
It can be removed. Check out EvilSpeed and click on tech articles for the writeup.
This post has been edited by SpedToe169: Mar 7, 2004 - 12:05 PM
post Mar 8, 2004 - 11:38 AM
spedtoe do you know how to get rid of the rev limiter not just the speed govrnor?
post Mar 8, 2004 - 11:53 AM
boosted_K2
Joined Aug 30, '02
From Michigan
well removing the govenor or not... to utilize the modification would mean traveling over 111MPH as speedtoe said, so reguardless to use it is illegal lol
No but I don't buy it
Cause I'm...
post Mar 8, 2004 - 11:55 AM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
Unless your engine is modified to withstand higher RPM, or you like engine replacement, don't mess with the rev limiter. You'd be almost assured to damage something on a motor without some reworking.
*EDIT My spelling is bad*
This post has been edited by S_C_M: Mar 8, 2004 - 10:24 PM
post Mar 8, 2004 - 6:44 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
yeah def dont mess with the rev limiter, my buddy put on a comp on his gsr an it didnt have a rev limit an blew the motor at onl 45k... it sucked.. but he had everything to rebuild it.. but it was a nice bill, he got
post Mar 8, 2004 - 7:14 PM
SpedToe169
From Dallas, Tx
You cannot change the revlimiter without getting an aftermarket ECU. Probably in the neighborhood of $1300 + labor (minimum). And like everybody said, theres not much point on the street without upgraded internals.
post Mar 8, 2004 - 11:10 PM
dang that sux, cause thats mostly how i lose races....the other car go to like 6500-7500 before shifting and i'm down at freaking 5800 confused.gif mad.gif mad.gif
post Mar 9, 2004 - 12:24 AM
SpedToe169
From Dallas, Tx
You're not going to win races by rasing the rev limiter dude.
post Mar 9, 2004 - 12:41 AM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
post Mar 9, 2004 - 8:30 AM
ConeTrouble
Joined Nov 25, '03
From Mizzeri
QUOTE (SpedToe169 @ Mar 9, 2004 - 5:24 AM)
w3rd
post Mar 9, 2004 - 9:33 AM
SpedToe169
From Dallas, Tx
Your maximum power is somewhere around 5800 anyways.
No, its higher than that. Peak torque is at about 4500. Peak power is somewhere north of 6k, but I don't remember the exact number.
Lo-Fi Version Time is now: July 12th, 2026 - 8:03 AM
