> flywheel for st, help
post Mar 14, 2004 - 7:19 PM
kuruptedsnake
Joined Jun 13, '03
From brooksville,fl
can some one please give me a link or a website that carries a flywheel for the 97 celica st
post Mar 17, 2004 - 6:50 PM
3TST
Joined Sep 27, '02
From UK
NOPI online Catalogue
Clutch/Transmission
Flywheel
Clutch Master Lightened Flywheel - 4cyl 1.8L Eng - Billet ALUMINUM
or
Competition Clutches Flywheel - 4cyl 1.8L - Lightweight Aluminum
BUT THEY ARE NOT CHEAP!
http://129.33.208.33/ecat2004/dsp_parts.cf...20Celica%201997
post Mar 18, 2004 - 3:32 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
if you just want a stock 6 bolt flywheel, then let me know... i have a spare 4/7a-fe flywheel here which was used for only about a year.... i do have a picture and there's TONS of life in it.... all of the teeth on it are perfect.... I don't need it for i did a 4a-ge swap (which uses an 8 bolt flywheel....)... oh yeah... i'm asking $30 US for it (picture here: http://www.cardomain.com/memberpage/219038/10 )
heh.... if you even want... i'll have coomer come over and inspect it for ya wink.gif
This post has been edited by toyotaspeed_90: Mar 18, 2004 - 3:36 AM
post Mar 18, 2004 - 11:14 PM
kuruptedsnake
Joined Jun 13, '03
From brooksville,fl
HOW BOUT THAT STRUT BAR DOES THAT FIT MY ST ILL BUY THAT OFF U
post Mar 19, 2004 - 2:57 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
no.... celica's use a 4 bolt upper strut, and the corollas use a 3 bolt
post Mar 19, 2004 - 6:17 PM
3TST
Joined Sep 27, '02
From UK
..celica's use a 4 bolt upper strut
Not on mine it doesn't!
I have a 3 bolt upper struct pattern front and rear.
post Mar 19, 2004 - 10:27 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
QUOTE (3TST @ Mar 19, 2004 - 11:17 PM)
what year do you have?
Coomers car (ST).... he doesn't have a bar either and i pulled it off the wall (cause that's where i keep it) and the bolt patterns were WAY off (couldn't even redrill holes in the ends for it) and used a 4 bolt pattern in the front.....
Lo-Fi Version Time is now: August 29th, 2026 - 7:41 PM
