Mar 15, 2004 - 1:52 AM
Enthusiast ![]() ![]() ![]() Joined Feb 20, '04 From Washington Currently Offline Reputation: 0 (0%) |
Any one have any last minute tips about installing Coilovers?? I have some from "DropZOne" and I'm putting them in tomarrow along with my rims. Anything helps~!
Mar 15, 2004 - 3:48 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
if u need to grind ur struts, u might want to invest in several dremel sandpaper bits. several of mine wore off then flew off, lol. also use alot of grease when putting ur front ones in so that it doesnt squeak. also when taking the assembly off from under the car, loosen the top bolt a little so that when removing it all the way, it isn't as hard.
Mar 15, 2004 - 7:32 PM
Enthusiast ![]() ![]() Joined Nov 17, '03 From New York Currently Offline Reputation: 1 (100%) |
When i installed my coilovers i ran into problems with the front. The top piece that came with the coilovers ruined my pressure plates, i dont know if yours will be the same, just put it all together before you instal and make sure nothing rubs at the top. If you bought new struts you will need to grind the front and back down. use a lot of grease and have fun.
| Lo-Fi Version | Time is now: June 13th, 2026 - 8:43 PM |
