Mar 15, 2004 - 12:59 PM
Does anyone have any detailed information about the cruise control lever and how exactly the switches work electrically?
I'm thinking that it would be pretty cool to hook up my power windows so that when I press the lever up, they'd both go up, or when I press the lever down, they'd both go down. Or maybe use the button on the end and a couple SPDT relays to switch windows, and then operate each window individually using the lever. -------------------- New Toyota project coming soon...
Mar 15, 2004 - 1:47 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 25, '03 From cranston RI Currently Offline Reputation: 0 (0%) |
that would definetly be hot... gives me some ideas since my cruise doesnt work anymore for some reason... hmm now you got me thinking all kinds of crazy things... like wiring it to my stereo remote control... volume up/down, prev/next track select, all that cool stuff.... hmm.... i am very interested in this electronics info...
Mar 15, 2004 - 1:57 PM
Yeah, if I can figure out the electricals of how that switch works, I can hopefully do this over spring break.
Mar 15, 2004 - 6:04 PM
![]() Enthusiast ![]() Joined Feb 22, '04 From Reykjavík Iceland Currently Offline Reputation: 0 (0%) |
i want Cruise control... just imagine 200 km/h and going steady
to bad european cars dont usually come with cruise control |
Mar 15, 2004 - 6:24 PM
I kinda wish I had it too, but I'd rather have my engine that I've got now and no cruise control! I gotta find a way to put that lever to use though. -------------------- New Toyota project coming soon...
Mar 16, 2004 - 1:07 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
just an idea if this works out
you could make it so normally it does your window only but with the cruise control built in it does both or something , or you could just custom wire a button to put down the windows , but I understnad your just trying to get thise lever put to use. good luck let us know if you figure anything out to use it for |
Mar 16, 2004 - 1:27 PM
Idk if the celicas work this way, but the way i kno is that the actuator controls a valve which limits the air intake. Less air, less combustion. Have the actuator control the windows but u'd have to run wires from it. Take into consideration u'd have to eliminate the brake pedal CC release. too. Probably easy enuf as cutting a wire. But the cc system probably also reads speed and throttle position and everything else.
When it comes down to it the control lever is just a switch, so idk why you couldnt use it like any other. What im curious about, is if you can use the sensors to do other functions. If you can use the system to monitor something else, and then function in consequence to a variable. This post has been edited by Supersprynt: Mar 16, 2004 - 1:38 PM -------------------- |
| Lo-Fi Version | Time is now: March 23rd, 2026 - 7:58 PM |
