Mar 16, 2004 - 7:15 PM
Hi,
Since I've gotten the car back, I've begun to hate my lightweight flywheel. I'm thinking that now my next modification will be a stock AE86 flywheel. The main problem I have with the flywheel is the fact that the engine and entire car shudders horribly whenever the engine sees below 1,600 RPM or so and the car is in gear. Whether I'm starting from a stop, or driving really slow in a parking lot, the car will shudder horribly if it sees low RPMs. When starting from a stop, I have to rev the car all the way up to at least 1,600 RPM or so...it feels like I'm slipping the clutch, and that's why it's so hard to get used to. I always want to give it less gas, but then the car shudders so badly. Also, this makes it near impossible to start quickly from a start without spinning the tires. Whenever I try, the engine simply bogs down and shakes when I try to start quickly from a stop. Does anyone else have this problem with their lightweight flywheel? -------------------- New Toyota project coming soon...
Mar 16, 2004 - 7:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
well Coomer,
I have driven a CRX with a lighten flywheel and i had to rev the engine to 1500 rpm b4 i could get it to roll.. I guess you will just have to get use to it and ride the clutch longer. This post has been edited by Hanyo: Mar 16, 2004 - 7:32 PM |
Mar 16, 2004 - 7:40 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
my fidanza lightweight flywheel wont link up with my starter correct, im thinking of going back to stock too... not a fan of the ligthweight flywheel
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Mar 16, 2004 - 9:50 PM
Enthusiast ![]() ![]() Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
Maybe you should contact Fidanza about this, I'm sure they'd at least be interested in your problem, if not try to help you out somehow. I haven't had any problems with my Fidanza (in an ST). Coomer, my car sometimes shudders under conditions similar to yours, but only when I am attempting to accelerate from a low RPM. Mine doesn't do this all the time, however, so I'm not sure if I'm just doing something a bit different. Sorry I don't have a solution for you. Your swap looks awesome, BTW. Reminds me of my old FC Rx7 though, I could get it lurching really badly in 2nd gear, to the point where nausea was induced for both occupants. I hated that car until I learned how to drive a manual. |
Mar 16, 2004 - 10:35 PM
Enthusiast ![]() ![]() Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
check this out.... it helps a bit:
http://club4ag.com/faq%20and%20tech_pages/FAQ.html#4A-GE/GZE Flywheel Choice...how heavy? |
Mar 16, 2004 - 11:01 PM
actually fidanza knows about the problem, many MR2 owners have talked to the people at fidanza about it. i dont think theres anything i can really do about it currently unfortunatly
Mar 17, 2004 - 4:38 AM
Enthusiast ![]() ![]() Joined May 8, '03 From San Jose, CA Currently Offline Reputation: 0 (0%) |
I have the same issues with my lightweight. I think this is "normal".
You will get used to feathering the gas to take off. - aba |
Mar 17, 2004 - 5:39 AM
Enthusiast ![]() ![]() Joined Dec 21, '03 From Lynnwood, WA Currently Offline Reputation: 0 (0%) |
So does it mean if we gonna install a lightweigh flywheel in any cars, we also need to launch ours at least 2000 RPM or more to drive as normal??
Mar 17, 2004 - 8:39 AM
no not at all, i can actually get my car moving w/o stalling out without even getting on the gas.
Mar 17, 2004 - 10:29 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
The lightweight flywheel reduces the inerertia of the motor, which means if you miss the power band of the motor a little, the inertia of the fly wheel will not keep your car running and the system will bog down.... think of it like, your margin for error in shifting ha now been greatly reduced..
I choose to get my 3SGTE flywheel lightened by like 5 - 7 lbs as opposed to getting an uber light one.. just made more sense to me since this car is my daily driver. -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Mar 17, 2004 - 12:00 PM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
Yeah, tried a lightened one in my dunebuggy, BIG mistake, stalled easier, had to rev more to get going, a REAL problem when you're in the middle of a creek or a mudhole or trying to go up a hill w/o stalling or spinning the wheels and sliding down the hill backwards...needless to say, it came right back out. They now make billet STEEL crank pulleys for air cooled VW's (along with counterweighted cranks) to ADD mass to help smooth out the motors.
Mar 17, 2004 - 12:16 PM
My friend has 2 buggies and a couple bodies. Unfortunately one was just in an accident and so beause its totally fiberglass, the body is in 2 pieces. Pretty loud, crazy, fun cars tho! I was considering putting in a fidanza, but perhaps i should just stay stock. Doesnt seem like alot of people are content after spending $300. This post has been edited by Supersprynt: Mar 17, 2004 - 12:54 PM -------------------- |
Mar 17, 2004 - 6:35 PM
Enthusiast ![]() ![]() ![]() Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) |
Are you sure it's the flywheel causing the problem and not the clutch?
(or may be a combination of both) I have a genuine TRD clutch with standard flywheel fitted on my ST and I have this similar "shuddering" problem especially in stop/start traffic. I have to increase the revs to pull away cleanly. FYI: NOPI online catalogue is interesting reading when it comes to clutches. They also have Clutch Master and Competition Clutch lightened/lightweight flywheels for the ST. |
Mar 20, 2004 - 5:41 PM
Enthusiast ![]() ![]() ![]() Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) |
Coomer,
What you describe is perfectly normal. You won't hurt the clutch any by slipping it off the line, thats how it was designed to be used. If you think thats a pain, you should try driving one of our world challenge cars in traffic (in the pits, not on the street, I would never do that, heh heh heh). They have like 6lb flywheels, lightened crank/rods/pistons (only slightly as per the VTS) and a 5.5" triple plate clutch. They idle at like 1400rpm and you can't get them moving without stalling them below about 3000. The clutch is almost totally an on off switch. As far as launching your car, a little bit of wheel spin is good. On a street tire you're looking for about 15% slip off the line for the best launch. |
| Lo-Fi Version | Time is now: August 26th, 2026 - 12:30 PM |
