> Parking brake, Not working
post Mar 17, 2004 - 1:22 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
I did a rear disc conversion. everything works fine except my parking brake. Do I need new parking brake pads? or what? Any help would be beneficial.
jeremy
post Mar 17, 2004 - 3:11 PM
mikew04
Joined Feb 19, '04
From austin tx
On the stock rear disk brakes, there are small drum brakes for just the parking brake. dunno if that helps any...
post Mar 17, 2004 - 4:48 PM
Anub1s
Joined Nov 27, '03
You might want to adjust the tension in the parking break cable. You just need to pry off that little divider where the shifter is and everything and there is a nut you tighten to increase the tension. If that doesnt work then it probably is those pesky brake pads in the small drum in the back.
post Mar 17, 2004 - 10:22 PM
Jeremy1210
Joined Dec 16, '02
I did adjust the tension in the inside of the car. I am still using the Parking brake cable from my ST. It is a little longer thatn the GT's... thniking maybe I need to put some spacers or something on the cable to shorten it.. Anyone think that it might work??
post Mar 19, 2004 - 11:13 PM
rsos1
Joined Nov 5, '02
From Illinois
you can also adjust them right at the wheel, theres a little spoked thing you turn and it make the two pads go out or in, its at the bottom of the two pads.
post Mar 20, 2004 - 11:11 AM
Jeremy1210
Joined Dec 16, '02
Thanks Rsos. I didn't read that part in the chilton manual. lol THey work fine now
post Mar 20, 2004 - 7:07 PM
rsos1
Joined Nov 5, '02
From Illinois
no problem glad to help
Lo-Fi Version Time is now: August 28th, 2026 - 6:18 AM
