Mar 18, 2004 - 6:54 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
all the wires are plugged in the right spots and everything appears to be connected right.
does this mean my head unit is messed up? or the factory 2 amps are messed up? this is an aftermarket head unit, using the metra 70-8112 harness going through the factory amps. please help , i jsut want cd capability |
brianforster head unit not turning on Mar 18, 2004 - 6:54 PM
Yobbe So you get no response from the headunit other the... Mar 18, 2004 - 8:04 PM
brianforster exactly
i think the head unit is blown because i ... Mar 18, 2004 - 8:05 PM
Yobbe Sounds like the headunit is blown yeah... unless i... Mar 18, 2004 - 8:30 PM
brianforster nope its pretty old kenwood kdc-217
ill look it u... Mar 18, 2004 - 8:32 PM
3TST DON'T QUOTE ME ON THIS but
There are normally ... Mar 18, 2004 - 8:47 PM
Yobbe The KDC-217 manual has the following solution to w... Mar 18, 2004 - 8:47 PM
Yobbe 3TST is right i think ... The harness should suppl... Mar 18, 2004 - 8:52 PM
3TST I think the 2nd IGN power wire that goes to the ig... Mar 18, 2004 - 10:18 PM
brianforster ok the head unit has 3 wires that i know need to b... Mar 18, 2004 - 10:59 PM
Yobbe OK, time for me to sleep ... Looking forward to re... Mar 18, 2004 - 11:36 PM
brianforster what could be the problem if hooking up all the wi... Mar 18, 2004 - 11:37 PM
Burt try hooking the head unit up to the battery direct... Mar 18, 2004 - 11:46 PM
brianforster but if the stock amps were blown the head unit wou... Mar 18, 2004 - 11:50 PM
Burt yea Mar 18, 2004 - 11:52 PM
Burt well actually if the power is running through the ... Mar 18, 2004 - 11:55 PM
brianforster its not even getting that far Mar 18, 2004 - 11:55 PM
Burt what do you mean its not getting that far? Mar 18, 2004 - 11:57 PM
brianforster i hook all the wires up and i get absolutely nothi... Mar 18, 2004 - 11:58 PM
Burt i will brainstorm and post what i come up with bef... Mar 19, 2004 - 12:01 AM
brianforster ok thank you Mar 19, 2004 - 12:54 AM
brianforster well this morning i wired it to the battery and no... Mar 19, 2004 - 7:58 AM
3TST Help is on it's way...
I'll do a couple of... Mar 19, 2004 - 8:23 AM
brianforster i dont have it yet
also the stock head unit no ... Mar 19, 2004 - 8:54 AM
Drocay Just get a after market headunit and it will be fi... Mar 19, 2004 - 9:17 AM
brianforster I have the 8 speaker upgrade, theres 2 factory amp... Mar 19, 2004 - 9:18 AM
Anub1s Im thinking you will have to do some serious custo... Mar 19, 2004 - 12:00 PM
brianforster I think I might have blown my factory amp what are... Mar 19, 2004 - 12:43 PM
Drocay http://www.installdr.com/InstallDocs/Toyota/PDF/86... Mar 19, 2004 - 1:39 PM
brianforster thanks droc looking at that now
more update:
i ... Mar 19, 2004 - 2:36 PM
brianforster damn that pdf didnt realy help because my stock am... Mar 19, 2004 - 3:00 PM
brianforster and i cant seem to find any clips under the amp ju... Mar 19, 2004 - 3:37 PM
Yobbe Do you have a tool for measuring the wires ? Check... Mar 19, 2004 - 3:39 PM
brianforster no unfortunately I dont, but I have tried connecti... Mar 19, 2004 - 3:41 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 15th, 2026 - 5:26 PM |
