Mar 20, 2004 - 8:37 AM
Enthusiast ![]() ![]() ![]() Joined Nov 15, '03 From mississippi Currently Offline Reputation: 0 (0%) |
what type of sub works best in the doors? I have had experience with sealled and ported boxes but I have never placed subs in the doors before. I would like the best SQ possible. Please help
William |
Mar 20, 2004 - 8:40 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
free air subs would do well in the doors but only if you do not plan on putting subs in the rear.
I suggest 6.5 components for the doors if you want best possible SQ |
Mar 20, 2004 - 9:01 AM
I was thinking subs in front and back
whatcha think William |
Mar 20, 2004 - 9:04 AM
well the 8 inch in the doors probably wont make people go "holy crap" when you go by, it just adds a nice thump if your not gonna have bass in the back.
I would go with 6.5 components myself so I dont have to worry about another amp but it is possible to do the 8's in the doors and more subs in the back. also keep in mind our hatches usually rattle with bass so your door wll prolly annoy the piss out of you unless you tigthen down everything |
Mar 20, 2004 - 9:07 AM
thanx for the info
peace |
Mar 20, 2004 - 10:10 AM
Enthusiast ![]() ![]() ![]() Joined Aug 21, '03 From Endicott NY Currently Offline Reputation: 0 (0%) |
You definately would want free air subs. They sound great, I definately would suggest using dynamat on the doors it will make a big difference. I would suggest add a pair of tweeters if you going to add subs. That way you'll have the base and still have good sounding music.
Mar 20, 2004 - 10:31 AM
well I should have also said that I am going to make fiberglass kick panels for the front I was thinking of a component system proably type -r's.
William |
Mar 20, 2004 - 10:44 AM
Enthusiast ![]() ![]() ![]() Joined Feb 23, '03 From Florida Currently Offline Reputation: 0 (0%) |
Well maybe this will help in your journey, I will be using the following for my doors;
MB Quart RCE216 Component Set... Now here is what I am doing, since door speakers generally sound like **** simple by adjusting your window up or down you loose depth. so what I plan to do is box out the back of the speaker area, and reform my bottom door panel (where the speaker grill and map pocket are) to create a ported box, this will give my speakers the depth it needs and keep it from changing its resonance when rolling up and down the window. Keep in mind when your going for SQ (Sound quality) everything has to appear to be coming from the front of the car, in theory if you turn your radio on and close your eyes you are suppose to be able to hear each instrument play exactly where it suppose to on a stage. Putting 8's in your front door panel wont help at all, in order to achieve sound quality your mids and highs must be strongest up front, and your rear fill (normally coaxials in the rear) are to be roughly mid level from the front (example if you ran 60w each to your fronts, 30w or 40w each would be sufficient for the rear fill) your subs should keep up with your fronts therefore 60w to each sub would NOT be sufficient since it has a longer travel to your ear than the fronts, so 120w to the rear each would be sufficient...of course this is just a rough example none of these figures mean jack ****... im just explaining staging. oh, and NEVER use a headunit to power your door speakers... you could buy the best speakers offered, if you power em with your HU you mine as well have stock speakers. |
Mar 20, 2004 - 2:21 PM
Enthusiast ![]() ![]() ![]() Joined Sep 22, '02 From Detroit Currently Offline Reputation: 0 (0%) |
I've had 8" subs in my doors for a couple years now(I even wrote a How-To). There is a lot of rattle to fix, but it's well worth it.
| Lo-Fi Version | Time is now: August 21st, 2026 - 3:41 AM |
