Mar 23, 2004 - 8:56 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
When i wired up my HU, i also wired the dimmer. The problem is that when i turn the dimmer up, the HU lights get dimmer,... and when i turn the dimmer down, the HU gets brighter while the dash lights get dimmer (except if its turned all the way over, then everythings bright). Is there a fix?
BTW its a Blaupunkt HU Thanks -------------------- ![]() |
Mar 23, 2004 - 10:11 PM
Enthusiast ![]() ![]() Joined Nov 26, '03 From McKenzie, TN Currently Offline Reputation: 0 (0%) |
So ur HU is on the same dimmer as your dash lights? Sounds like you may need two separate dimmers. I dont know why it would be doing that though. It doesnt make sense b/c as long as its wired up correctly all the dimmer does is control the amount of current going to the lights. All I can think of is that it may somehow be diverting the unused current to the HU when you turn down the dash lights, kind of like it does w/ the lights on the AC controls.
| Lo-Fi Version | Time is now: August 27th, 2026 - 11:08 AM |
