> im getting a pop, when i turn????
post Mar 24, 2004 - 8:44 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
ok, so when i turn into a parking space or somthin, when im goign slow, i get a pop, what is this? does any one have the same thing or know what it is or how to fix it , thanks.
post Mar 24, 2004 - 8:58 PM
RedSunCelica
From San Diego CA
Check CV boots probably broken. also check around the inside of the rim check for any grease that is on the rim this also points to CV boots being ****ed up
post Mar 25, 2004 - 11:53 PM
96stcoupe
Joined Nov 3, '03
From Iowa
I am getting the same thing. I think it might be my rear sway bar links because it started right after I lowered my car last week. Hopefully next week I will have time to take a closer look. If you find something out in the meantime though, let me know. wink.gif
post Mar 26, 2004 - 1:30 AM
Stealths95GT
Joined Apr 19, '03
From Washington
i get it on a slow down...and is it from the rear...if so...i am willing to bet its the ebrake...i know i had mine fixed on the driver side when i bought the car...and now the passenger side is going frown.gif i think i am gonna replace both this time...
post Mar 26, 2004 - 11:30 AM
94silverst
Joined Feb 20, '04
From Washington
I installed coilovers on my car last week and I was getting this same problem! Only when I was going slow though confused.gif ! Well it turned out that my top hat was upside down tongue.gif ! That fixed the poping BUT I still had a noise comming from the front when I turned slow. I sparyed it with WD-40 and now the noise is gone!! I would suggest (if there is more to it than just a pop) pin-point the location of the noise and spray the sucker down! Can't hurt! Hope this helps!
post Mar 26, 2004 - 12:17 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE (94silverst @ Mar 26, 2004 - 4:30 PM)
from what i read, if you got ground controle, there is this pop you get, you have to buy somthing, for it.. cant remember but im sure theres plenty of peopel that know.. but mine is only when im going slow an turn hard.. I also have lowering springs, an i think i might get an aloignment, cause after all that snow an ice, my car is shaking at higher speeds, like 60+ like an on off sterring wheel shake thats it, but anoing
post Mar 27, 2004 - 12:16 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
If you have DropZone's you need to grease up the caps that rest on teh bearings really well before you let it back on the ground...otherwise spring makes a hideous popping sound when you turn the wheel.
post Mar 27, 2004 - 1:08 AM
96stcoupe
Joined Nov 3, '03
From Iowa
QUOTE (Digndoug @ Mar 26, 2004 - 11:17 AM)
Thats prolly not an alignment problem. Get your wheel balance checked.
post Mar 27, 2004 - 4:59 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
SpedToe169 sells them through his website and it fixes the pop, click Here
Team 6gc 2005
Lo-Fi Version Time is now: August 9th, 2026 - 9:20 AM
