Apr 5, 2004 - 4:48 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Ahh ok, I was thinking each led needed a resistor. You said that the 5mm led's are more work than the 3 mm why is that? They won't fit?
Apr 8, 2004 - 12:16 AM
Enthusiast ![]() ![]() ![]() Joined Feb 23, '03 From Florida Currently Offline Reputation: 0 (0%) |
They will fit on the circuit board of course, but they will not fit when you try and put the plastic pieces back in (these are used so the light centers into each button rather than all over the place).
As you seen by the pics the LEDs they used where flat, so 3mm makes it just fine but 5mm is a whole nother story unless u bore out the plastic. |
| Lo-Fi Version | Time is now: September 14th, 2026 - 4:55 AM |
